EGT gauge checkup
Old Oct 8, 2002 | 07:08 AM
dwilson's Avatar
Default EGT gauge checkup
Alright, i just installed a Greddy EGT gauge. I just want to make sure it is functioning properly. It is installed in the third runner of my manifold and the lights are all working. i have it wired as follows:
Red wire-hot all the time
Orange wire- is to the ignition wire( where it is hot after turning switch on)
White wire- to the running ligts
Black wire- ground
Does all of the connections look correct. The reason i am asking is i just got my new motor back in with turbo set up and at idle it is sitting on like 300C i think that is what the gauge reads in. Does this sound normal or right? Any help would be appreciated.
[Modified by dwilson, 4:10 PM 10/8/2002]
Old Oct 8, 2002 | 07:20 AM
falcongsr's Avatar
What is this crap?
Default Re: EGT gauge checkup (dwilson)
sounds good to me
Old Oct 8, 2002 | 07:26 AM
dwilson's Avatar
Default Re: EGT gauge checkup (falconGSR)
so the temp sounds right at idle
Old Oct 8, 2002 | 08:27 AM
racerxadam's Avatar
my greddy egt gauge doesn't register any significant temp at idle either. If you hold the revs to 3500 for a few seconds it should begin to climb a bit.
Old Oct 8, 2002 | 08:29 AM
falcongsr's Avatar
What is this crap?
Default Re: EGT gauge checkup (racerxadam)
yes the temp sounds right at idle...racerxadam where is your egt probe? if its in the downpipe, you might not see any temps at idle...hmm.
Old Oct 8, 2002 | 10:10 AM
dwilson's Avatar
thanks guys i was fixing to take out all the wiring and redo
rob1235
May 18, 2011 04:17 PM
SoHc94
Jan 18, 2011 08:18 PM
blackeg
Jan 13, 2008 06:21 AM
eth0r
Nov 10, 2005 03:31 AM
Mike813
Jun 4, 2004 08:28 AM
