ecu help
ok i searched and can't find anyting useful. i know this much. i need a p28 ecu i'm planning to chip it with neptune. i have a d16y7. what p28 do i need? and/or wireing harness conversion? i'm just confused because of the vtec. do i have to modify the harness or the ecu to be compatible?
A D16Y7 motor is non VTEC, which means you can use a P28 if you want, but it isnt necessary since you wont be using VTEC.
Any chipped OBD1 ECU will work fine for you...VTEC or NON.
I currently have ECU/Neptune RTP deals for $600 shipped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wonk Unit »</TD></TR><TR><TD CLASS="quote">if i were to use a p28 would i need a special conversion harness or just an OBD2 to obd1 harness?</TD></TR></TABLE>
just the normal OBD2 (a or b) to OBD1 would be fine if your car is 96+...this is a 5 speed right?
You would not need a p28 on a d16y7, however you could use one and simply not use vtec in Neptune RTP.
The obd2 to obd1 harnesses are the same regardless if you have a vtec engine or not.
So really all you need is a obd2 to obd1 harness for your vehicle + neptune rtp installed in a obd1 non-vtec ecu.
The other thing you would need is a tuner to tune the car unless you are capable of it. You can find tuners in the honda-tech tuner directory listed in the forced induction section as a sticky.
Good Luck
Good Luck
cool ok so how do i know if i'm obd2a or b? and i talked to a tuner in albuquerque and he said somehting like $550 to tune it, plus 300 for neptune and 60 bucks to put it in. does that sound right?
sorry for the noob qustions, but i searched and couldn't find anything. thanks for all the help
veilsides2000
Jan 1, 2005 09:17 AM
