eclipse or volvo turbo in integra
Old Oct 15, 2008 | 10:37 AM
eg customs's Avatar
Default eclipse or volvo turbo in integra
how will a turbo from a mitsubishi eclipse or volvo turbo work on a ls vtec. will it work good
Old Oct 15, 2008 | 10:40 AM
Schister66's Avatar
Man U FTW
"Good" is all a matter of opinion. Personally, i dont think either of those turbos is going to be a great unit for your LS/VTEC. What are you trying to accomplish??
Old Oct 15, 2008 | 11:06 AM
ITR-EKcoupe's Avatar
Default Re: eclipse or volvo turbo in integra (eg customs)
not too sure about the volvo turbo but my buddy has an eclipse T25 on his b18 and it likes to fall off around 7000. if your not looking for huge HP numbers its OKAY. its better than not having it on, but hes running the turbo way out of its efficiency range and its soon to take a crap as its already starting to whine less than 6 months later. but in my eyes it was a good cheap way to get into turbo's. get the feel for it and what not. that way your charge pipes and stuff are already run, just bolt on a bigger turbo that runs the t25 flange (as there are tons of options) when the lil one decides its had enuf. and most importantly get it tuned properly by someone that knows what they're doing.
Old Oct 15, 2008 | 11:41 AM
Puscifer's Avatar
It all depends on how much power you are trying to obtain. The stock 14b will net you in the neighborhood of 200-250whp maybe more. You could do a Evo3 16g and have an easy 300-350+whp setup and something that'd spool up ridiculously fast.
Old Oct 15, 2008 | 08:36 PM
TheShodan's Avatar
Moderator
Default Re: (Puscifer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Puscifer &raquo;</TD></TR><TR><TD CLASS="quote">It all depends on how much power you are trying to obtain. The stock 14b will net you in the neighborhood of 200-250whp maybe more. You could do a Evo3 16g and have an easy 300-350+whp setup and something that'd spool up ridiculously fast.</TD></TR></TABLE>
Honda cylinder head CFM efficiency will net about 260whp at most for a 16g. Hondas unlike other makes don't like the backpressures that those turbos give on unlike the 4G63. it's not a DSM, don't treat it like one.
Old Oct 16, 2008 | 06:05 AM
eg customs's Avatar
so if i put the eclipse one how much should i expect out of it, the motors is an ls block with ls pistons and gsr head. approximatly how many horse power will it pull out?
Old Oct 16, 2008 | 06:57 AM
nsxmatt's Avatar
Default Re: (eg customs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg customs &raquo;</TD></TR><TR><TD CLASS="quote">so if i put the eclipse one how much should i expect out of it, the motors is an ls block with ls pistons and gsr head. approximatly how many horse power will it pull out?</TD></TR></TABLE>
They just told you two posts up what you could expect.
Old Oct 16, 2008 | 07:19 AM
TheShodan's Avatar
Moderator
maybe 175whp or so
Old Oct 16, 2008 | 09:06 AM
HiProfile's Avatar
Default Re: (TheShodan)
It depends on WHICH eclipse you get it from. The 1g DSM's use the 14b - there is one particular person here who made 240whp on a D16 (and it had a bad cylinder). There are also other examples that made over 200whp with decent spools. THe problem is you spent all that money on the VTEC head, but want to run a tiny turbo. The LS head would have been better for your goals, which seem to revolve around low-end and tiny turbos.
Old Oct 16, 2008 | 05:58 PM
eg customs's Avatar
Default Re: (HiProfile)
so for how much can i get a new garrett turbo. im only going to boost 9 psi
Old Oct 17, 2008 | 04:26 AM
nsxmatt's Avatar
You really need to go and search some past threads and do some research on what setup you actually want. Then go to the classifieds and price out turbos based on the size you pick.
Old Oct 17, 2008 | 06:16 AM
UK Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg customs &raquo;</TD></TR><TR><TD CLASS="quote">so for how much can i get a new garrett turbo. im only going to boost 9 psi</TD></TR></TABLE>
Why to people get so hung up on the psi?
You need a hp goal and then piece your turbo set up around that.
You also need to consider if you want a fast spooling turbo or something that comes on harder later and has a better top end.
Go do some research as there is so much info on this site.
Old Oct 17, 2008 | 07:22 AM
TheShodan's Avatar
Moderator
Default Re: (UK Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UK Accord &raquo;</TD></TR><TR><TD CLASS="quote">
Unfortunately thats common for those that have never boosted before and think there's a direct relationship between power and pressure for all turbos regardless of size. It does get rather bothersome.
Old Oct 17, 2008 | 04:34 PM
IndySporty's Avatar
Yep, I remember those days. Hehe....
Scotty Dosent Know
Aug 2, 2006 05:04 PM
blackpearlcivic
Feb 1, 2006 08:07 AM
Keangdawizes
Jun 9, 2005 05:50 PM
ekzrated
Feb 16, 2005 07:28 AM
