Eclipse dyno video, 611 whp. (27 psi, 75 nos)
Re: Eclipse dyno video, 611 whp. (HXMan)
i know, the motor shake is pretty freaky, huh ?
its one badd *** motor setup though.
ill be the 1st to give the guy props on his setup.
good job
good job
Re: (diputs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diputs »</TD></TR><TR><TD CLASS="quote">What's up with the engine shaking and stumbling when it's spraying the 75 shot on the dyno?</TD></TR></TABLE>
i believe its breaking loose on the rollers???
It's compressor surge from the engine not being able to keep up with the instant spool when he sprays. That video is OLD. He has run high 10s in that car.
Re: Eclipse dyno video, 611 whp. (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid »</TD></TR><TR><TD CLASS="quote">coolness</TD></TR></TABLE>
hell yeah!
hell yeah!
Re: (Pooptooth)
Compressor surge due to the 7 cm housing he was running on the turbo. With the spray, it would cause it to surge. He has since swapped to an 8cm housing which has solved the surge problem. Turbo is an FP Red.
jeff
Re: Eclipse dyno video, 611 whp. (FBP Si 2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBP Si 2000 »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Faster than ur car huh jackson
Re: Eclipse dyno video, 611 whp. (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP »</TD></TR><TR><TD CLASS="quote">
Faster than ur car huh jackson </TD></TR></TABLE>
And yours. :0
And yours. :0
If You Slip You Die
09-01-2005 08:34 AM
accordfreak
12-16-2003 07:32 PM
