ebay kit, good enough?
Old Jul 1, 2005 | 04:23 PM
thrty8street's Avatar
Default ebay kit, good enough?
http://cgi.ebay.com/ebaymotors...%3AIT
the internal wastegate spring is set to 12psi, is there anyway to lower it to like 7 psi? also can you lower it with a boost controler? im not looking to boost more than 7-8 psi.
Old Jul 1, 2005 | 04:28 PM
MooreBoost's Avatar
Default Re: ebay kit, good enough? (thrty8street)
You're going to lose some pressure through the intercooler anyway.
Just get your boost source from before the intercooler and you should be OK.
You can't lower it with a boost controller, you will have to swap the wastegate actuator.
Old Jul 1, 2005 | 04:38 PM
Default Re: ebay kit, good enough? (MooreBoost)
ok, how do i swap the wastegate acutator and where do i find one with a lower psi rating spring? also how does the boost controler work if i cant lower the pressure?
Old Jul 1, 2005 | 06:13 PM
b16ahybrid's Avatar
search online for a new actuator.
The wastegate works by fooling the wastegate into thinking that the turbo is producing less boost then it really is.....You can only raise the boost with a boost controller, not lower it....do a seach on wastegate or go to http://www.howstuffworks.com it's be alot faster...
If you do like it was mentioned above you will probably only be getting about 9psi or so to the motor anyways....(plumb pre intercooler)
Old Jul 1, 2005 | 08:16 PM
MooreBoost's Avatar
Default Re: ebay kit, good enough? (b16ahybrid)
I wouldn't even bother with the new actuator.
That's a pretty small turbo, so you should easily be able to handle a few extra psi from it with tuning.
What are you tuning with?
BlUAc
May 20, 2006 09:43 AM
avsrule414
Dec 10, 2005 09:07 AM
AZNracerx1989
Jul 18, 2005 10:12 AM
Racer X
Mar 27, 2003 01:07 PM
technine
Jun 11, 2002 05:08 PM
