Eagle Rods?
Old Oct 12, 2001 | 12:07 PM
SpeedBump's Avatar
Default Eagle Rods?
what do you guys think of eagle rods. I have a gsr powered civic with a turbonetics t3/t4 turbo. I want to boost about 6 or 7 pounds daily and boost about 12 to 14 pounds when needed. What do you guys think?
Also what pistons do all of you prefer and what compression? Thanks.
Old Oct 12, 2001 | 12:17 PM
dustin's Avatar
Default Re: Eagle Rods? (SpeedBump)
Eagle rods are good rods, and they are awesome the money. My LS is getting a set.
Dustin
Old Oct 12, 2001 | 12:22 PM
TurboInteg95's Avatar
Default Re: Eagle Rods? (dustin)
I think if you're not going to be sleeving a block, eagle rods are the way to go. People seem to like using them with the Endyn/Wiseco pistons.
Old Oct 12, 2001 | 01:07 PM
954DR's Avatar
New User
Default Re: Eagle Rods? (TurboInteg95)
TurboInteg95 - If you're not sleeving they're the way to go?
I'm having Golden Eagle sleeve my block. Why not use the Eagle/RW combo w/ a sleeved block?
[Modified by 954DR, 10:07 PM 10/12/2001]
Old Oct 12, 2001 | 01:21 PM
ArizonaTurbo's Avatar
For the Money; You can't go wrong!
Old Oct 12, 2001 | 02:21 PM
DamonBoost's Avatar
New User
Default Re: Eagle Rods? (APEXSER)
I have eagle rods.. They were put in my motor after the first one was blown.. Not a problem yet.. knock on wood
[Modified by ill logic, 6:49 PM 10/12/2001]
Old Oct 12, 2001 | 02:54 PM
Default Re: Eagle Rods? (954DR)
well so far I havent seen any proof that the eagle rods are as strong as Crowers. It just seeems like a good idea that if you're investing that much money to have your block sleeved, you might as well go with the Crower rods that are proven to over 600hp.
Old Oct 14, 2001 | 06:26 AM
speedworks's Avatar
have installed several sets of eagles with no problems to date, some over 2.5 years ago. great rods
Old Oct 14, 2001 | 10:11 AM
synergy004's Avatar
Default Re: Eagle Rods? (speedworks)
I have them, I read H beams are one of the strongest made rods. Sport Compact car and several dealers quoted this. I am using them with a block guard and JE pistons. THey are great. Good for the money and seems to be great for the strength.
LOL peace out
Old Oct 14, 2001 | 08:26 PM
SiR Kid's Avatar
New User
Default Re: Eagle Rods? (synergy004)
JG made a 769 HP at the flywheel motor with straight out of the box eagle rods... They help up without issues.
JG prefers Eagle rods for their motors.
Old Oct 15, 2001 | 06:59 AM
jamal-188's Avatar
Default Re: Eagle Rods? (SiR Kid)
Where's a good place to get them? What pistons would you guys recommend to lower compression and go w/ these rods?
Old Oct 15, 2001 | 01:43 PM
Default Re: Eagle Rods? (jamal-188)
You can get them at http://www.raceeng.com ! We just installed JE's w/ Eagle rods in my buddy's 92 hatch (94 B18C1) along with a Cometic .030" headgasket and Nuformz block guard! We ran the car this weekend here at the IDRC event in Arizona! He netted a best of 12.02 @ 115 @ 14.5 psi ! We ended up going with 9.0:1 CR JE's! The kit consists of:
Log type Stainless Steel Manifold
T3/T04E (.63 housing Stage III Turbine & 57 trim .60 A/R Compressor)
RC Engineering 310cc Injectors
Vortech FMU (8:1 Disc)
2.5" - 3.0" Downpipe
XS Engineering Silvia Core (20 x 10.94 x 3)
JE 81.5mm 9.0:1 CR Pistons
HPC Coatings (Pistons, Manifold, Downpipe, Exhaust Housing)
Eagle Rods
Cometic .030" Headgasket
Nuformz Block Guard (Not Welded)
The car hauls *** at only 1 bar! We are going to dyno it next week to see what kind of power it is making!
SOHC_me
Nov 13, 2006 09:43 AM
jdm2teg
Apr 7, 2006 05:41 AM
1.8T_EG
Feb 5, 2003 11:01 AM
Civicdrgrcr
Nov 19, 2002 04:47 PM
maximedx
12
Jan 29, 2002 05:44 AM
