Eagle Rod install
Old Dec 29, 2009 | 02:52 PM
crxcel's Avatar
Default Eagle Rod install
Does the casting numbers go to intake or exhaust side when installing? Eagle likes to put you to there voice message and never phone ya back. I would Imagine they are the same as a stock honda rod but just want to make sure
Old Dec 29, 2009 | 04:05 PM
hybrdthry911's Avatar
Default Re: Eagle Rod install
i install my rods like oem honda does, the bearing tangs, on the exhaust side.
Old Dec 29, 2009 | 08:40 PM
cleansi's Avatar
x2 good luck with your build
Old Dec 30, 2009 | 10:39 AM
welfarepc's Avatar
and if i remember correctly, the "casting marks" are on the tang side. so you should be all good in the hood.
Old Dec 30, 2009 | 04:15 PM
hondapowerb16a2's Avatar
I did mine like OEM but after my machinist said eagles don't have the internal oiling and are symmetric so it doesn't matter which way they face
Old Dec 30, 2009 | 06:47 PM
blackeg's Avatar
tangs on the exhaust side, so that puts the oiling hole on the intake side when you put the bearings in
Sketch_hs
Mar 18, 2006 07:16 PM
itralex
Sep 11, 2004 03:16 AM
HYBRIDSIRACCORD
Jun 13, 2004 07:29 PM
infamousALLMTR
Sep 20, 2002 08:32 AM
