E85 tune toggle?
I was thinking of running E85 since it's pretty widely available by me, I'm looking to see what set ups have a toggle for one tune on 93 and then another on E85. From what I've read Hondata has something that allows you to toggle between tunes on the fly, and I'd like more information.
Also, if I just used a fuel cell with E85 could I run a Y in the fuel lines with two separate fuel filters before the Y?
QUOTE
The S300 can control boost by using a duty cycle controlled output on OBD1 ECU pin A11 with a boost control solenoid to regulate air to the wastegate.
Boost may be fixed, or varied by gear, with two settings which allow for wet/dry, pump/race gas or street tire/slicks settings to be selected with an external switch
/QUOTE
You can wire up a switch to trigger 1 different map.
/QUOTE
make sure you have a wideband. If you haven't bought tuning software yet, just so you know Neptune RTP has a feature where you can have 3 completely different tunes already and yes can switch on the go.
Personally I would pick a fuel and stick with it.
hotimportcrx
17
Dec 5, 2005 04:52 PM
99TurboFerio
Mar 5, 2005 02:29 PM
