E85 question
Old Jul 7, 2012 | 09:42 AM
  #26
TheShodan's Avatar
Moderator
Default Re: E85 question
Originally Posted by VtecCarHauler
Yes, it does take more fuel to make the same power as gasoline. What makes Ethanol so attractive besides price is that it has cooling properties not found in other race fuels. If you think of it the whole point of using race fuels with higher octane is to control the timing of the combustion happening in our engines. Even if you are not using the E85 to it's potential the comfort of having added safety outweighs cost if there even is any. Many ppl have near the same mpg as 93 octane on a n/a or turbo honda running e85. The b-series engine is one of the most efficient engines so with good street tune the mpg wont be as bad as most would think. 1000cc injectors with the walbro intank will support 300-400 or even higher depending on the efficiency of your setup. Run a thicker than stock gauge power wire to the fuel pump on a relay for more fuel pressure.
Best thing to do is ask ppl who actually run e85 as the negative criticism comes from those who do not even run e85 in a race car or daily driver or may have had bad experience due to other reasons besides the fuel.
I wouldn't say that, and this is coming frome someone who did E85, and went away from it due to the inconsistencies that you so eloquently stated earlier in your last post. The negative comments are not without merit; it really looks more into how you're using your car, as the term "daily driver" is a very loaded word on this forum. For those of us using higher power levels over 350, and have other transportation, that term is very loosely applied: Getting it by the drum in some regions are as much if not similar to race gas prices in bulk, depending upon use.
So yes.. its subjective and will continue to be a debatable topic on many forums, but the negatives are not simply from people that "hate on" E85 for no other reason than its existance.
Old Jul 7, 2012 | 10:33 AM
  #27
the red eg's Avatar
As far as dd goes I have other vehicles I can drive. The inconsistency of e85 is something that does concern me. If I run pump gas none of stations here have 93 for some reason so would be stuck on 91
Old Jul 7, 2012 | 03:59 PM
  #28
wantboost's Avatar
Who is Mr Robot?
That's because of where you live... Past a certain point west there is no 93... Only 91. And e85 is very inconsistent so unless you have an ethanol content sensor you're never going to really have a safe tune on e85
Stick to 91
Old Jul 7, 2012 | 04:28 PM
  #29
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It's called be smarter than your fuel. I am so sick of these pathetic threads. If you don't have the money to run higher horsepower, let alone daily, then maybe you should rethink your setup.
If you want to run E85 - have multiple tunes (and means to switch them on the spot) and a tester/analyzer. This and/or means of increasing the ethonal content.
If you want to run pump gas - you *should* have multiple tunes anyways. You never know when that last gas station around might have problems/run out of premium fuel. If your octane is limited, get a good water/Meth setup to help compensate.
It's all just pure laziness of people that prevents cars from being exceptional.
Old Jul 7, 2012 | 04:57 PM
  #30
grumblemarc's Avatar
The Grumpiest
Like button?
Old Jul 8, 2012 | 11:42 PM
  #31
rico892002's Avatar
its funny how people fight back if forth about e85 vs gasoline.. it really isnt that serious..gasoline is junk and it always will be junk unless we get some old **** from back in the day lol..People always talk about how inconsistant e85 is..it really isnt. I tell people u think everytime u pull up to the pump and get 93oct its gonna be 93oct. no its not..They have sites you can go to and see when most places switch to there winter blends, if u dont trust the site, just test the fuel yourself around winter months. For a street car set up, i wouldnt be tuning the car to the edge anyways to worried about how inconsistant e85 is. I run e85 in my set up, since ive been running i think i checked the fuel once. never had a problem.I do make sure i throw a bottle of lucas lubricant in there.
Old Jul 9, 2012 | 07:14 AM
  #32
TheShodan's Avatar
Moderator
This debate will continue for both advocates and opponents of the use of the fuel. Your statement of "93 will always be junk" is hardly even a remotely convincing argument to win someone over on this particular thread. But I'm glad that you enjoy the use of it and understand that even using "lucas lubricant" is still a way of showing concern for the risks of its use.
I think this thread (like the other E85 vs Gasoline fuels) should go ahead and die now, as there will never be a definitive answer. Good luck to everyone.
Old Jul 9, 2012 | 02:03 PM
  #33
rico892002's Avatar
good way to end it lol
carlos8
Nov 20, 2013 04:29 PM
aem
Oct 4, 2009 05:31 AM
civiceg92
Mar 30, 2004 10:32 AM
civ96
Feb 5, 2003 04:43 PM
smoothludey2
Oct 10, 2001 08:17 PM
