E85 fuel race
Who is Mr Robot?
I HAVE PERSONALLY RAN E85 FOR A YEAR ON A WHALBRO 255 AND STOCK LINES THROUGH RC INJECTORS WITH NO PROBLEMS AND THE GAS SAT FOR 6-8 MONTHS AFTER AND I HAD NO PROBLEMS ON START UP. STILL RUNNING THE SAME SETUP TODAY SAME PUMP SAME LINES SAME INJECTORS
Was that hard to understand?
Everyone using E85 from the pump should check the content for consistency. Depending on season and how they have the blender pump set it can vary from station to station or week to week. If you find a good blend, stick with that station but continue to verify blend.
Around here people using pump E85 report usually 70%-85% range when they test (water test method).
Who is Mr Robot?
Current ASTM standard I believe allows 51% to 85% allowable ethanol content.
that's seriously impressive. are you running the normal filter sock?
boostedblue23
Oct 4, 2017 05:38 PM
