E85 Build
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostfed-r »</TD></TR><TR><TD CLASS="quote">i run a jdm ITR Turbo with an sc34..looing to make around 315</TD></TR></TABLE>
you will be fine, get a FPR though
Actually the stock FPR will be fine, just get a gauge if anything.
The reason it would work - with the same size pump, you bypass ~30% LESS fuel through the FPR. Given that a 255HP on a stock FPR only bumps if up ~10-15psi (~30% more), it should probably stay around stock if 30% more fuel is going through the injectors instead. Worst case you get a few extra PSI of fuel at idle, but you have to retune the entire map anyways.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">Actually the stock FPR will be fine, just get a gauge if anything.
The reason it would work - with the same size pump, you bypass ~30% LESS fuel through the FPR. Given that a 255HP on a stock FPR only bumps if up ~10-15psi (~30% more), it should probably stay around stock if 30% more fuel is going through the injectors instead. Worst case you get a few extra PSI of fuel at idle, but you have to retune the entire map anyways.</TD></TR></TABLE>
yea, but I bet his high compression JDM ITR makes more than 315whp with that SC34 and E85, so why not just add the FPR, its not like it costs $400
do i need an adjustable fuel pressure reg. if im running walbro 255lph with stock fuel rail on turbo
92gsrteg
Aug 25, 2005 11:00 PM
ceemarun
May 29, 2002 02:18 PM
