e-mange vs AFC NEO
Old Nov 15, 2008 | 10:36 AM
EK_kidd's Avatar
Default e-mange vs AFC NEO
i been trying to figure out which one is better? i'd try searching for this topic and i didnt find anything.. i need some advise plzz..
i have a t3,dsm 450,going on a d16y8(civic ex) if any of that info helps..
thanks
Old Nov 15, 2008 | 11:43 AM
quicksilver1689's Avatar
i ♥ snails
AFC's just suck for our application no good
Emanage with the right harnes ie: ignition and fuel can control fuel and timing maps alot better than an afc but when u consider the price why wouldnt u want to go the chipped route. Easy, flexible, you can dial your car in to run perfect in all areas.
Old Nov 15, 2008 | 09:59 PM
HiProfile's Avatar
Default Re: e-mange vs AFC NEO (EK_kidd)
I'll sum it up using your signature:
"my looks = bitches.. My looks+my car = more bitches.." --> my looks+my car+ecu based engine control = HELLA more bitches
Both listed methods are only good if you want to 'beat' the OBD2 emissions people. But IIRC Florida doesn't even require emissions, so I'm not sure why you'd bother with either setup. Both will cost MORE THAN a decent street tune. However, neither will make more power...
Old Nov 15, 2008 | 11:57 PM
EK_kidd's Avatar
Default Re: e-mange vs AFC NEO (HiProfile)
Then what should I do? I was under the impression that with one of those hacks I can tune my car everyday if I wanted to.. What should I get?
Old Nov 16, 2008 | 11:16 AM
SovXietday's Avatar
Don't use a hack, have the ECU chipped and tuned. Research this.
That is of course unless you want to show those bitches a good time camping on the side of the road.
Old Nov 16, 2008 | 06:58 PM
EK_kidd's Avatar
Default Re: e-mange vs AFC NEO (SovXietday)
Yeah I did some research. And found out that I have to send my ecu out every time I want to get a tune. And plus the chip is not tune to my max hp of my car.. Right?
EL TYPE R
Mar 7, 2013 09:33 AM
project-boosteD
Engine Management and Tuning
16
Apr 28, 2011 03:33 PM
raverx3m
Sep 22, 2010 10:46 PM
RnR EVO 8
May 21, 2008 07:22 AM
Dougs96SI
Jan 12, 2005 02:11 PM
