e manage question
Old Apr 23, 2004 | 06:17 PM
Black Si's Avatar
Default e manage question
i have the full greddy e manage kit and i am buying a laptop this week to tune it with but the kit comes with a serial to usb cord and most laptops come with only usb ports now days so my question is has anyone here used a usb to usb cord with there e manage
also i posted this in tech but will include it here incase anyone has any input:
im swaping a b16 into my eg civic and it will be turboed about a week after i do my swap. my question is if i install my 450cc injectors will the car run off of my factory ecu or will it be to rich? i have the full greddy e manage kit and will be installing it eventually but i just want to know if it will run in the mean time.
Old Apr 23, 2004 | 07:16 PM
boostngsr's Avatar
Default Re: e manage question (Black Si)
you will need a 9 pin adapter because the code you input in the computer is used as a password by the cord that comes with the greddy unit. if you don't use it then you will not be able to link up. i have heard of a crack floating around, but your on your own for that. check the yahoo posts on emanage, lots of info there
Old Apr 23, 2004 | 07:25 PM
Black Si's Avatar
Default Re: e manage question (boostngsr)
thanks for your help
Old Apr 23, 2004 | 09:13 PM
hiendgsr's Avatar
word of advice--don't buy anything bigger than 370cc injectors. I was forced to use those on my GSR. The e-manage sucks ***, I hate it. My distributor coil has fried twice now and has continuous problems. It was installed by a good shop and tuned on a dyno (277 @ 10psi) but this is not a good daily driver setup. I'm switching to hondata as soon as i recover from the expenses of getting the emanage setup.
Old Apr 23, 2004 | 10:32 PM
This One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Si &raquo;</TD></TR><TR><TD CLASS="quote">i have the full greddy e manage kit and i am buying a laptop this week to tune it with but the kit comes with a serial to usb cord and most laptops come with only usb ports now days so my question is has anyone here used a usb to usb cord with there e manage
im swaping a b16 into my eg civic and it will be turboed about a week after i do my swap. my question is if i install my 450cc injectors will the car run off of my factory ecu or will it be to rich? i have the full greddy e manage kit and will be installing it eventually but i just want to know if it will run in the mean time.</TD></TR></TABLE>
You have to use one of greddy's cords, Or one of the copy ones.
Its not as simple as a USB cord.
The e-manage will compensate for the 450 when you type it up in the parameters
It wont run until then though
Old Apr 23, 2004 | 10:34 PM
This One's Avatar
Default Re: e manage question (hiendgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hiendgsr &raquo;</TD></TR><TR><TD CLASS="quote">word of advice--don't buy anything bigger than 370cc injectors. I was forced to use those on my GSR. The e-manage sucks ***, I hate it. My distributor coil has fried twice now and has continuous problems. It was installed by a good shop and tuned on a dyno (277 @ 10psi) but this is not a good daily driver setup. I'm switching to hondata as soon as i recover from the expenses of getting the emanage setup.</TD></TR></TABLE>
I have 370's and its run fine.
I am going bigger soon.
And what does the e-manage have to do with frying your coils?
Its prefectly fine for daily driving, as a matter of fact, its a very good option for daily driven.
Hondata is much more than a basic E-manage setup
Old Apr 29, 2004 | 06:51 PM
Black Si's Avatar
thanks for the help
do any of you have a base map that i can use on my e manage
its a b16a w/ turbo at about 8 psi , 450cc injectors
Old Apr 30, 2004 | 08:06 AM
SolidGround_Accord's Avatar
e-manage ignition harness messes up your distributor. It messed up my ls/vtec. It wouldnt even crank sometimes. Fried a couple of ignition coils. The fuel side works fine but the ignition side messes things up. Did the same to my friends supra. Ignition harness not worth it.
Old Apr 30, 2004 | 09:24 AM
DA-MAX's Avatar
Default Re: (SolidGround_Accord)
I wonder if the "diode trick" will work like it has on my friends Maxima...we installed diodes(forgot what kind) inline on the ignition output wires to the coils(6 direct coils) and so far to this day not ONE burnt coil. we ran up to 1* retard and no probs, only thing is, with the diode trick I don't think you can advance timing, only retard
sqwale
Sep 26, 2005 07:18 PM
SdGSR01
Feb 2, 2005 06:22 PM
Scean
Mar 30, 2004 11:41 AM
awalk2005
Mar 8, 2004 12:25 PM
