E-manage Ignition Harness Install help
Old Oct 5, 2004 | 02:38 PM
bh2285's Avatar
Default E-manage Ignition Harness Install help
hello all, I have installed the emanage in my GSR del sol OBD1 and i was just seeing if any one knew how to put in the ignition harness. This is the extra harness they sell. I know that i only use the ch1 input and output but i dont know what wire coming out of the dis. I have my MSD hooked up with the MSD cap and i have the one wire running throgh the cap( i guess it tells the MSD the timing) would this be the wire i hook the e-manage up to also. Any help please, thanks for your time.
Old Oct 5, 2004 | 06:54 PM
bh2285's Avatar
Default Re: E-manage Ignition Harness Install help (bh2285)
bump
Old Oct 5, 2004 | 08:18 PM
fuccarlos's Avatar
the emanage wire hooks up to your ecu pin a-21 you use only two wires on the ignition harness the dark blue w/white line and the dark blue w/black line
Old Oct 5, 2004 | 08:54 PM
bh2285's Avatar
Default Re: E-manage Ignition Harness Install help (fuccarlos)
thanks man ..its a input output deal right?
Old Oct 6, 2004 | 12:47 AM
fuccarlos's Avatar
yep and if you have a pin right below a-21 which is a-22 then you cut both wires an connect both together and hook them up to the in side of the harness same with the out side of the harness
mozzandherb
May 29, 2015 04:03 AM
mozzandherb
May 28, 2015 06:11 AM
24boosted
Honda Civic (2006 - 2015)
Mar 9, 2008 12:29 PM
Excelerate
Jun 9, 2004 07:31 AM
killa_lude
Aug 16, 2003 08:29 AM
