E-cutout and Oil Catchcan?
Old Oct 15, 2006 | 09:51 PM
sitinthehall's Avatar
Default E-cutout and Oil Catchcan?
I've been looking into the exhaust e-cutout and I'm currently running a oil catchcan. If I route the catch can into the exhaust behind the cat, but run the cutout before the cat, will I still get enough vacuum to suck out the blow by? Does anyone have any other ideas about where to route the catchcan into the exhaust?
I'm not really wanting to run an open breather either...
Old Oct 16, 2006 | 03:44 PM
sc4dr's Avatar
Default Re: E-cutout and Oil Catchcan? (sitinthehall)
Maybe its just me, but I've never heard of any one doing this?
Old Oct 16, 2006 | 04:05 PM
siblues's Avatar
Default Re: E-cutout and Oil Catchcan? (sc4dr)
Here goes everything you need to know
https://honda-tech.com/zerothread?id=1199935
Old Oct 16, 2006 | 06:13 PM
blackeg's Avatar
Default Re: E-cutout and Oil Catchcan? (siblues)
ive heard of many people doing this, but more on race cars than street cars. all you really need is your catchcan to be the easiest, least restrictive way out of the block for the gas to escape, which could be as simple as just a breather filter
Old Oct 16, 2006 | 06:22 PM
siblues's Avatar
Default Re: E-cutout and Oil Catchcan? (blackeg)
I dont disagree with the filter option but most cases with people just using a filter end up in crankcase ventilation problems and blowby?I may be wrong but most of the experienced motor guys stand by the catch can method so i tend to think they know what is going on?I am in no way saying you dont just stating my opinion.
Old Oct 16, 2006 | 09:45 PM
I forgot that I could run it off of the wastegate dump... I feel like an idiot now. Thanks for the input guys
Old Oct 17, 2006 | 02:15 AM
blackeg's Avatar
the filter would be on the top of the catchcan, which goes directly from the back of the block to the catchcan, you can do whatever you want with the valve cover hole
Old Oct 17, 2006 | 04:05 AM
sc4dr's Avatar
I run the Endyn catch can kit, works great. It uses siphon fittings on the back of the block, so it limits liquid build up in the catch can. I run a breather on mine, but you can choose to use a pcv valve on top, instead of a breather. The kit is like $160 but its complete and it works well.
Old Oct 17, 2006 | 05:04 AM
turbotime's Avatar
got my kit off ebay using the OEM honda fittings, Paid about $60 for everything including can and lines.
Open breather, works perfect. Oh and not that many high hp guys use exhaust slachcut. My tuner is making 600+whp and just runs 2 cans, both open breather.
EJ ITO
27
May 29, 2010 04:17 PM
square_1
Nov 28, 2008 10:17 AM
94civicexlsvtec
May 16, 2004 10:36 AM
b16supertuner
May 13, 2004 08:38 PM
Maengelito
Sep 18, 2002 07:31 PM
