whats up with this?
Re: (instrument)
oil filter relocation? You serious? And how does that work? Im guessing a braided hose to the back of the block where the filter would normally go, then a fitting at the other end of wherever you want it?
Correct me if im wrong
Re: (EJ ITO)
pretty much yea, i assume people use it that race (professionally) and change their oil after every race. but anyone could use it if you dont like crawling under your car.
Re: (DCSportEJ1Civic)
We make and sell oil relocation kits. Basically theres a plate in the back that screws on where the oil filter goes. Then theres 2 lines that come out to another plate that you now bolt your oil filter too. Makes oil changes a breeze.
Banned
Re: (yoffer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a3delsol »</TD></TR><TR><TD CLASS="quote">what kind of header is that on that motor. Its wild looking. </TD></TR></TABLE>
Its an anr actually.
Re: (watsvtecEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by watsvtecEK »</TD></TR><TR><TD CLASS="quote">
Its an anr actually. </TD></TR></TABLE>
Banned
Re: (watsvtecEK)
Good call
After looking at it, you can see that the differences are minimal.
ANR Header
Bisimoto Header
Im wondering if anr has different coatings. Because Bisi uses ceramic coatings on most, if not all, of his headers.
Good call
ANR Header
Bisimoto Header
Re: (yoffer)
actualy its neither, if you look at the flanges it dosent match the anr one. idk waht kind it is, jsut stating its not the correct one ppl are saying
Re: (MugenManR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenManR »</TD></TR><TR><TD CLASS="quote">actualy its neither, if you look at the flanges it dosent match the anr one. idk waht kind it is, jsut stating its not the correct one ppl are saying </TD></TR></TABLE>
Flanges are not a key part to a manifold.
Here is an old thread about that car before it went ITBs. Look on the last picture and youll see ANR Stainless header.
https://honda-tech.com/zerothread?id=1313614
This thread totally went sideways.
Re: (yoffer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer »</TD></TR><TR><TD CLASS="quote">Not really its still tech and we're still answering questions and giving out good information.</TD></TR></TABLE>
Correct but at the cost of the original question. We went from oil relocation to header, to now debating if its still on course or not.
Re: (Taimaishui14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Taimaishui14 »</TD></TR><TR><TD CLASS="quote">To bring this topic - back on topic, do you have a website where people can buy them, or a marketplace thread?</TD></TR></TABLE>
Was that addressed to me? If so no not yet. We are working on both at the moment.
Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
Was that addressed to me? If so no not yet. We are working on both at the moment. </TD></TR></TABLE>
I would be interested in this as well.
Re: whats up with this?
ok i just finish installing my permacool oil filter relocation kit from summitracing,i double check everything to see if its installed correctly which it is.now put oil 4quarts but the oil pressure light stays on and wont go away,so i add another quart of oil total of 5quarts and still the light still on.there is no leak whatsoever i disconnect battery for 10 min and stilll the light wont go away.any suggestions what should i look for or anything i can do?thanks
yes im 100% percent sending unit is hook up as for the lines hhmm i might have to recheck but im pretty sure its hook up right.could be the line too long?i located the filter right just next to the coolant reserve bottle and under the stock air filter box.would it be safe if i have 5 quarts of oil in the motor?or shold i drain some?thanks
ya 5 quarts should be lots as long as you don't have 20 feet of -10 line. maybe try a differant oil pressure sender. does it tick when its running can you see oil geting to the head ( oil filler hole in valve cover
ok i figured out what was wrong the lines were backwards.thanks for the help
