dynojet results at 6lbs
Old Dec 5, 2003 | 08:45 AM
boostedsol's Avatar
Default dynojet results at 6lbs
Well, i wanted to see what kind of power i was making at only 6 psi. Here are the results of a third gear run. The car is a built ls, stroker crank, 3/4 deck plate, stock head. only street tuned a bit on an aem ems and running rich.
191.6 hp and 188.5 torque ... very close numbers. Tell me what you think:
Old Dec 5, 2003 | 08:51 AM
rocket256's Avatar
Default Re: dynojet results at 6lbs (boostedsol)
nice tq ; but has alot of spikes in Hp!
Old Dec 5, 2003 | 09:04 AM
accordexchange's Avatar
Default Re: dynojet results at 6lbs (rocket256)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket256 &raquo;</TD></TR><TR><TD CLASS="quote">nice tq ; but has alot of spikes in Hp!</TD></TR></TABLE>
Old Dec 5, 2003 | 10:18 AM
Johnyquest's Avatar
Default Re: dynojet results at 6lbs (accordexchange)
yeah dude, your definatley having some problems with the way that tq curve goes up and down! What are you tuning it with?
edit:
I noticed your using ems... you lose 20 ft/lbs of torque then get it right back in what looks like 1k rpms... what gives?
Old Dec 5, 2003 | 03:20 PM
boostedsol's Avatar
Default Re: dynojet results at 6lbs (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">
I noticed your using ems... you lose 20 ft/lbs of torque then get it right back in what looks like 1k rpms... what gives?</TD></TR></TABLE>
good question... I was expecting higher numbers but maybe with more boost things will start to straighten out. But like i said, my car was only mildly street tuned.
so for 6 psi would you all say this is bad?
Old Dec 5, 2003 | 03:37 PM
Teg4e's Avatar
can you post a full picture of the plot? i think b/c the pic is so zoomed in, it looks more spiky than it really is. also, whyre you only running 6psi on a built block?
Old Dec 5, 2003 | 04:05 PM
Lucky_Smurf's Avatar
Default Re: dynojet results at 6lbs (Teg4e)
Also what turbo are you running? Taht might help us determine if the peak is good or not.
Old Dec 6, 2003 | 12:58 AM
boostedsol's Avatar
Default Re: dynojet results at 6lbs (Lucky_Smurf)
ok , the turbo is of a ls drag 3 kit. turbonetics t3 t4 57 trim .63 ar i think. i haven't raised the boost because of a new break in. I have about 2500 miles on the new bottom end. Just want to start gradually. thanks for the help.
Old Dec 6, 2003 | 11:42 AM
Vtec or no on the head? I know LS is non but a lot of people do the conversion. If non those aren't bad numbers for a street tune. Get a good tuner and you can put up some really good numbers. I know a kid same turbo on a stock B16a with hondata. Got it tuned put 275whp not sure of the tq on 8 psi.
Old Dec 6, 2003 | 11:55 AM
igotyofire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsol &raquo;</TD></TR><TR><TD CLASS="quote">ok , the turbo is of a ls drag 3 kit. turbonetics t3 t4 57 trim .63 ar i think. i haven't raised the boost because of a new break in. I have about 2500 miles on the new bottom end. Just want to start gradually. thanks for the help.</TD></TR></TABLE>
heh dont u generally break in the motor 1st before slappin on a turbo kit
Old Dec 6, 2003 | 12:44 PM
boostedsol's Avatar
Default Re: dynojet results at 6lbs (igotyofire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">
heh dont u generally break in the motor 1st before slappin on a turbo kit</TD></TR></TABLE>
what i meant was, i wanted to start off on low boost then once i see everythings running good on 6 psi i'll raise it gradually. not just dump 20 lbs on right away.
Old Dec 6, 2003 | 12:55 PM
Archidictus's Avatar
Unceasing Measure
Is third gear on an LS tranny closer to a 1:1 ratio than 4th? Interesting chart there...can you make another pic so we can see the rpms? I'm wondering about the dips and the fuel curves too.
Old Dec 6, 2003 | 01:23 PM
boostedsol's Avatar
Default Re: dynojet results at 6lbs (Archidictus)
maybe this will help. here is the full image, didnt come out too well.
Old Dec 6, 2003 | 01:25 PM
boostedsol's Avatar
no fuel curves sorry.
Old Dec 6, 2003 | 01:31 PM
Teg4e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Is third gear on an LS tranny closer to a 1:1 ratio than 4th?</TD></TR></TABLE>
When I got my car dyno'd they used 4th gear.
Old Dec 6, 2003 | 01:39 PM
boostedsol's Avatar
Old Dec 6, 2003 | 01:42 PM
boostedsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teg4e &raquo;</TD></TR><TR><TD CLASS="quote">
When I got my car dyno'd they used 4th gear.</TD></TR></TABLE>
Yeah thats what i told them to do, then they were like fourth? na we use third gear so?
Old Dec 6, 2003 | 01:46 PM
rjardy's Avatar
The numbers seem low for an ls on 6 psi. Allso, they should have ran it in 4th. I dont know what they were thinking. Where diod you take it?
Rob
Old Dec 6, 2003 | 01:53 PM
boostedsol's Avatar
Default Re: dynojet results at 6lbs (rjardy)
I took it here to a local shop called evolution racing. They are new here and are the only ones in town with a dyno.
Hey rob, do you think my numbers would have been higher with a fourth gear pull?
Old Dec 6, 2003 | 02:29 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsol &raquo;</TD></TR><TR><TD CLASS="quote">Hey rob, do you think my numbers would have been higher with a fourth gear pull?</TD></TR></TABLE>
Regardless of whether they're higher or not, they'll be more accurate if you do a fourth gear pull.
BTW, now that I see the rpms, I can't help but think that some serious tuning still needs to be done to get the mean hp and torque numbers where they need to be. Those dips are pretty mean: can you feel them when you drive?
Old Dec 6, 2003 | 02:39 PM
boostedsol's Avatar
Those dips are pretty mean: can you feel them when you drive?</TD></TR></TABLE>
I really can't tell. The car feels really strong and pulls nice for 6 psi. I can def. tell a difference in torque from my stock block ls. The hp worries me though. Hopefully better tuning will help my car out.
Phoenix1
Aug 29, 2005 08:47 PM
flip1199
Jun 18, 2005 01:37 PM
TommyV
Honda S2000
Feb 24, 2004 10:44 AM
GSRswapandslow
Sep 22, 2003 08:08 PM
Ri5e
Aug 18, 2001 08:13 PM
