Dynoing my b16 boosted today!
setup is as follows:
B16
Exedy 8lb flywheel
ACT xtreme 6puck
revhard stg2 kit
440 RC injectors
AEBS intake manifold
Kazz LSD
2.5 all the way back
hondata s100b
p28
obd2>>obd1
9lbs of boost !! im shooting for 250 - 260 to the wheel am i dreaming?
B16
Exedy 8lb flywheel
ACT xtreme 6puck
revhard stg2 kit
440 RC injectors
Kazz LSD
hondata s100b
p28
obd2>>obd1
I made 225HP on a water break dyno and I have an all stock LS. A B16 makes 20 more hp than me. If you are going to a dynojet you will probably blow your expectaions away!
we dyno'd at 232 and it was only running 6psi ... stupid wastegate spring LIES! lol anyways trackmasters is like 1800 above sea level and there dyno reads a little low most people there with b16 make like 200ish ( 210? ) at the same number also running a 58mm TB kinda killed it a little in the high end i guess not really it was still pulling but i think with 3inch dp and exhuast with 62mm TB and some portflow inners and 9k will do some might good
1996GsrVtec
Jul 28, 2002 07:55 AM
