B16 SC61 dyno numbers
Old Oct 28, 2005 | 07:12 PM
nsxmatt's Avatar
Default B16 SC61 dyno numbers
Got my car to the dyno this evening and got a base tune on it. Still needs work but it did better than I thought..
setup..
Stock b16
Neukin manifold & 3" DP
Hondata s200b
SC61
RC550's
257.08 whp
Redline was at 8k, boost was at 5.5lbs
For reference my old car made about 240whp at 10psi and ran 11.7's
Needs some more tune and a little more boost and it should be good to go
Old Oct 28, 2005 | 07:14 PM
el arbi's Avatar
Default Re: B16 SC61 dyno numbers (nsxmatt)
Nice stuff Matt. Always running sick times with basically stock boosted motors lol.
Old Oct 28, 2005 | 07:30 PM
JDM_EH2's Avatar
Default Re: B16 SC61 dyno numbers (99SiRacer)
Sick numbers man! When are you seel full boost??
Old Oct 28, 2005 | 07:36 PM
VspecSiR's Avatar
Default Re: B16 SC61 dyno numbers (JDM_EH2)
sheesh, something tells me i should have gone sc61. can you use a/c with that turbo?
Old Oct 28, 2005 | 07:41 PM
nsxmatt's Avatar
I was thinking it hit 5 lbs by 4500. It hit's boost pretty hard compared to my 57 trim
I don't know if you can use a/c or not. I'm sure you can with the right manifold since it's not much bigger than my old one.
Old Oct 28, 2005 | 07:47 PM
siblues's Avatar
What ar and what housing are you using on that sc61?
Old Oct 28, 2005 | 07:51 PM
eg crunkmonster's Avatar
gawd damnnnn, how'd you do it? it must be the gas in indiana
Old Oct 29, 2005 | 03:37 AM
nsxmatt's Avatar
Default Re: B16 SC61 dyno numbers (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">What ar and what housing are you using on that sc61?</TD></TR></TABLE>
I think it's a .60/.63.
Old Oct 29, 2005 | 03:52 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">
I think it's a .60/.63.</TD></TR></TABLE>
What size compressor housing/cover did you get?
The T04S cover has a 4" inlet and 2.5" outlet and has a 0.70 AR
The T04E cover has a 3" inlet and 2" outlet and has a 0.60 AR
I just got the SC6152E myself with a T04S housing and 0.63 AR/5 bolt turbine. I'd like to know if your numbers were with an E or an S housing.
Old Oct 29, 2005 | 04:42 AM
nsxmatt's Avatar
Default Re: B16 SC61 dyno numbers (BlueShadow)
.60, it's the E cover. 5-bolt exhaust.
Old Oct 29, 2005 | 04:54 AM
88crxvtec's Avatar
according to the data logs he is hitting full boost at 4700 rpm, still need to tune before boost to spool it better but overall not bad for 5lbs. I think 260-270 will be pretty easy to reach.
Old Oct 29, 2005 | 04:56 AM
ramrod's Avatar
awesome numbers man.
im sure your really happy. keep us updated as to how it goes when you turn up the boost!
Old Oct 29, 2005 | 09:22 AM
nonvtecD's Avatar
Amazing numbers on 5 lbs
Old Oct 29, 2005 | 02:18 PM
yee SERIOUS's Avatar
that's really good for a sc61 on a stock block! good stuff matt
Old Oct 29, 2005 | 03:38 PM
VspecSiR's Avatar
Default Re: (undercoverdc2)
what are the average #'s put down on a SC61 @ that boost level?
Old Oct 29, 2005 | 04:39 PM
Jared's Avatar
sweet mang
Old Oct 29, 2005 | 05:54 PM
_gurusan_'s Avatar
Default Re: (Jared)
That's awesome, I'm stoked now. I'm going to be running a similar setup....but a short tubular manifold and an ITS SC61 killer....going to do 6 psi
Old Oct 29, 2005 | 06:06 PM
nfn15037's Avatar
Default Re: (VspecSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VspecSiR &raquo;</TD></TR><TR><TD CLASS="quote">what are the average #'s put down on a SC61 @ that boost level?</TD></TR></TABLE>
Most people don't bother to run this thing @ 5.5 lbs......it's sort of a waste to have a big snail like this that makes 5.5 lbs @ 4500 RPMs. At that HP level, you could run something that spools up a full thousand RPMs sooner and still make more than ~250 whp.
Old Oct 29, 2005 | 06:10 PM
coltboostin's Avatar
Default Re: (nfn15037)
What he said.
Be better off with a 50 trim and a .48AR turbine, unless you paln on ugrading the sweet open deck internals some time soon.
Old Oct 29, 2005 | 06:11 PM
_gurusan_'s Avatar
Default Re: (coltboostin)
yeah but if he wants to ever push it up to 9 psi or so that will place him in the 70-72% efficiency range and it will make a shitload of power
Old Oct 29, 2005 | 06:22 PM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">Most people don't bother to run this thing @ 5.5 lbs......it's sort of a waste to have a big snail like this that makes 5.5 lbs @ 4500 RPMs. At that HP level, you could run something that spools up a full thousand RPMs sooner and still make more than ~250 whp.</TD></TR></TABLE>
Spool difference is not a issue at the track, it's in boost the whole time. This turbo allows me to make the power I want down the road without having to purchase a new turbo every 6 months.
Old Oct 29, 2005 | 07:59 PM
SpeedingHatch's Avatar
Default Re: (nsxmatt)
do you have a graph?
Those are great numbers for such low boost
Old Oct 29, 2005 | 08:17 PM
Dublocivic's Avatar
Those #'s rock for five and a half pounds. Nice Job.
Old Oct 29, 2005 | 09:26 PM
Dancing is Forbidden's Avatar
Default Re: (Dublocivic)
what kind of numbers should I expect on a t3/60-1 on same setup?
Old Oct 29, 2005 | 09:35 PM
seen4ever's Avatar
Default Re: (ih8jdm)
really good numbers there sir
