Dynoed the old mans car
it was getting MAD wheelspin on the dyno, thats why it looks like it levels out and then spikes. I did not want to do 4th gear pulls. Car was fully tuned already and I saw no reason for loading it down just to get a cleaner dyno sheet.
17PSI
The RPM pickup was off on the dyno.. i don't know why but it was being reved out to 9500~
Where it says 8500 = 9500 the squiglly line at the end is from bouncing off the rev limiter.
it gets 12 psi @ 5500 and then just slowly creeps to 17.. I need to relocate the wastegate.
<FONT SIZE="18pt">BTW this was made THROUGH 3 inch CRUSH bent exhaust WITH A CAT</FONT>
Here is the setup or pretty much the setup
https://honda-tech.com/zerothread?id=1582472
17PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">I'm not seeing a pic, is it just me?</TD></TR></TABLE>
It's just you..You know you can't read those low hp dyno sheets.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">I'm not seeing a pic, is it just me?</TD></TR></TABLE>yeah...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">I've seen your dyno sheets before...
The ones where Kenny blew my motor on 300 whp at 18 psi??
</TD></TR></TABLE>The ones where Kenny blew my motor on 300 whp at 18 psi??
6th month old pump gas (92 octane, car sat for 6 months with no motor and this gas in it)
465 hp 279 torq
DynoJet
17psi with 9-10 degrees of timing.
and it had 12 psi @5500 ish and then just slowly krept to 17psi @9500rpms
I need to move the wastegate so it wont creep
465 hp 279 torq
DynoJet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon »</TD></TR><TR><TD CLASS="quote">Who program you use? From the looks of your sig...im guessing crome eh? Nice numbers by the way!
yea too bad it says chrome in his sig lol
</TD></TR></TABLE>yea too bad it says chrome in his sig lol
I believe dynojets measure HP via measuring acceleration of the drums. Then with the HP value and the rpm value given they plug into the HP=tq x RPM / 5252 equation. So if RPM is off, torque will be off, but not HP.
hmm thats interesting curve you got there...
cant quite figure out whats going on.
but usually, when the car breaks loose on the dyno... RPMS go up but since the rollers arent accelerating faster, the WHP does not go up.
Nice Josh!!
When we tuned my bitch at intec... we had some weird issue with the rpms in crome not matching those on the dyno, so we had to fatten it up hella in 1 narrow spot to figure out the differentiation between the two so we knew where it really was going lean...
Cant wait for this weekend, you gonna roll the oldmans whip???
BTW, what were AFs????
where the torq flattens out and kind of goes down, thats where the tires where spinning. It gets traction and starts to go back up. I hope to have the video up later today/tomorrow. I'll also post the .bin file for the motorolla 2.5 bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype »</TD></TR><TR><TD CLASS="quote">I believe dynojets measure HP via measuring acceleration of the drums. Then with the HP value and the rpm value given they plug into the HP=tq x RPM / 5252 equation. So if RPM is off, torque will be off, but not HP.</TD></TR></TABLE>
That is right, the tq is off not the hp.
PYITR821
Mar 16, 2005 02:28 AM
lol
