dynoed my turbo ls
Old Apr 22, 2005 | 09:17 AM
13sechatch's Avatar
Default dynoed my turbo ls
Well finally got my 94 LS integra done well thought done heres the set up.
ss autochrome mani t3/t4 turbo, rc440's walbro fuel pump spearco intercooler, tial bov and wastegate open wastegate 2.5 down pipe and rsr gt2 exhaust and autronic for engine management.
Well we got it on got it tuned for drivability and started the power runs and im going lean up top so my fuel pressure isnt high enough so my rev limit is set at 6krpms right now but even at that i made 233 to the wheels and the dyno graph is still going straight up so im expecting 280 easily just thought id share oh and these are dynodynamics numbers much lower than a dynojet or mustang dyno
Old Apr 22, 2005 | 09:25 AM
1RMDave's Avatar
Default Re: dynoed my turbo ls (13sechatch)
sounds good, what psi are you running? what trim turbo is that?
Old Apr 22, 2005 | 09:30 AM
D-tuned's Avatar
Default Re: dynoed my turbo ls (1RMDave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1RMDave &raquo;</TD></TR><TR><TD CLASS="quote">sounds good, what psi are you running? what trim turbo is that?</TD></TR></TABLE>
also some pics if you got any.
Old Apr 24, 2005 | 08:41 PM
13sechatch's Avatar
the turbo is .50 comp and .67turbine pics are on my cardomain dont have any of the new intercooler yet
http://www.cardomain.com/memberpage/815047
Old Apr 24, 2005 | 08:44 PM
tony n.'s Avatar
Default Re: (13sechatch)
how many psi are u runnin
Old Apr 24, 2005 | 08:48 PM
13sechatch's Avatar
oh and thats 10 psi
Old Apr 24, 2005 | 10:13 PM
95GSRTT
Guest
Posts: n/a
if its a completely stock head, then i wouldnt expect the power to go up at all. Its gonna fall flat on its face unless you got some boost creep going on.
Old Apr 24, 2005 | 10:17 PM
s2kdre's Avatar
Default Re: (95GSRTT)
after 6200 that head is done.
Old Apr 24, 2005 | 11:12 PM
dragit909's Avatar
HOW LONG HAVE YOU HAD THE TURBO KIT ON
Old Apr 26, 2005 | 11:05 AM
13sechatch's Avatar
not long ive tuned several turbo integra's im going to have no probs out of this one the motor is fairly new as well so it can handle it im going to eventually build it im just going to push the limits on it stock i know there are alot of people running 17psi on a stock motor i have no intentions to go about 15. and the car wont fall off up top even losing fuel the power was still climbing up
Old Apr 26, 2005 | 01:36 PM
DRAGLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13sechatch &raquo;</TD></TR><TR><TD CLASS="quote">the turbo is .50 comp and .67turbine </TD></TR></TABLE>
What turbo is this? never heard of it .50a/r doesn't say much and a .67a/r on the exhaust is that a custom housing?
Old Apr 26, 2005 | 01:38 PM
dustin's Avatar
Default Re: dynoed my turbo ls (dragit909)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragit909 &raquo;</TD></TR><TR><TD CLASS="quote">HOW LONG HAVE YOU HAD THE TURBO KIT ON</TD></TR></TABLE>
I'm guessing not too long since the manifold is still 1 piece.
Old Apr 26, 2005 | 01:43 PM
b16sedan's Avatar
Default Re: (DRAGLS)
.50 A/R is a TO4E comp housing. Not sure what .67 is, he probably just read the numbers wrong.
Old Apr 26, 2005 | 03:52 PM
13sechatch's Avatar
no i didnt read wrong thats what the place i got it from told me i am a tech but now that you say someting it doesnt sound right im thinkin its a .63a/r the compressor is .50a/r its a .57 trim
Old Apr 26, 2005 | 03:53 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13sechatch &raquo;</TD></TR><TR><TD CLASS="quote">.57 trim</TD></TR></TABLE>
It's 57 trim, not .57 trim.
Old Apr 26, 2005 | 09:41 PM
13sechatch's Avatar
wtf does it matter if the only purpose for you to post is to correct someone dont post. i got on a f#$kin . kick whoopidie do
Turbo93Eg
Mar 4, 2010 03:33 PM
millsd4
Apr 10, 2009 09:01 PM
175Shot4Door
Feb 3, 2009 04:35 PM
got2luvdarice13
Sep 8, 2007 05:59 AM
Smooth-GSR
May 3, 2004 03:11 PM
