Dynoed and A/F was 9???
Old Jul 15, 2002 | 01:44 PM
HybridCoupe's Avatar
Default Dynoed and A/F was 9???
I dynoed the other day and my car was at 11 A/F till 3500 rpm when boost kicked in and then went down drastically to 9 for some reason with the safc it wouldnt correct the prob no matter how much we leaned it out....im running a drag 3 kit with 12:1 fmu disk on stock injectors at 10psi?
Old Jul 15, 2002 | 01:49 PM
b18bturbo's Avatar
Default Re: Dynoed and A/F was 9??? (HybridCoupe)
what kind of wideband is that... is it tail pipe wideband or o2 bung style wideband. 9:1 af is damn rich... you car would fall flat in power.... how much pwr did it make by the way.. i think its faulty wideband more than anything else.
Sonny's Avatar
Did you lean it out only with the SAFC or did you try turning down the fuel pressure, too?
Sonny
Old Jul 15, 2002 | 09:18 PM
Default Re: Dynoed and A/F was 9??? (Sonny)
well i put down 214hp and 185 torque...i dont have a fuel pressure regulator....and we tried just tunning with the safc but it couldnt even budge the 9 A/F it was a dyno where they put the A/F tube in my downpipe and i ran the car...
Old Jul 15, 2002 | 09:27 PM
VaporTrail's Avatar
New User
me thinks faulty FMU. Then again, I always think that
Old Jul 15, 2002 | 09:28 PM
BoostinDC2's Avatar
there has to be something wrong with that
Old Jul 15, 2002 | 09:36 PM
Default Re: Dynoed and A/F was 9??? (BoostinDC2)
wrong with what....?
Old Jul 15, 2002 | 11:57 PM
ninesecrx's Avatar
If you hurt a piston or ring...it will throw the fuel mixture way rich like that when boost hits. Could be one of the cylenders fouling making it run rich.....Mike
Old Jul 16, 2002 | 12:07 AM
Sonny's Avatar
Don't overlook the fact that maybe it's just not tuned right. The JRSC's are famous for their bug-killing rich mixtures at high rpm's. When I first got my setup installed, it ran so rich at high rpm that it wouldn't even register on the wideband!
and then comes Hondata and the joy of playing basketball with my FMU.
Sonny
[Modified by Sonny, 1:07 AM 7/16/2002]
[Modified by Sonny, 1:08 AM 7/16/2002]
dapek
Engine Management and Tuning
Nov 6, 2008 10:33 PM
wpgcivic
Jul 7, 2004 05:45 AM
NOSED_CRX_VTEC
May 18, 2003 05:59 PM
BoostedD15B7
Apr 22, 2003 05:55 AM
00SIBOOST
Jan 10, 2003 10:01 PM
