Dyno-tune at Inline
Old Mar 24, 2003 | 07:43 PM
Infinity_Racer's Avatar
Default Dyno-tune at Inline
Well, my car made it to Inline without too much problem...John was the one doing all the tunning on it while on the Dyno...He set all the afc hack settings to -40% and it idled pretty nice...when i tried that, it didnt like it too much and it would bog, but as soon as John set it, it worked almost instantly ...He told me that my A/F reading was WAY rich when i first brought it in, meaning it wasnt even on the graph...but now its pretty steady and lean at 2-3K and slowly richens at around 3.5K...I was kinda mad cus my charge pipe kept popping off, but he juss slapped one together in no time...dyno'd my car and it ran 117whp w/ 117lbs at only 3psi... i have to buy a controller soon if "Unboosted Pelo Tudo's" doesnt come in soon...it barely hits 4psi and at around 5.25K, it begins to dip and lose HP...is it becuase of a leak in the charge pipes? well here's the dyno...nothing special, but hey it runs better and is driveable now...
Anyone have advice or tips for me?
To John for not giving me slack about my ghetto set up and for helping me out...
*Edit* I'm such a fob
[Modified by Infinity_Racer, 4:45 AM 3/25/2003]
Old Mar 24, 2003 | 07:50 PM
inspyral's Avatar
Default Re: Dyno-tune at Inline (Infinity_Racer)
is this a SOHC?
Old Mar 25, 2003 | 02:46 AM
Default Re: Dyno-tune at Inline (inspyral)
yeah its a sohc....d16z6
Old Mar 25, 2003 | 02:53 AM
swlabhot's Avatar
U need a microscpoe to see dat graph U ain't got a bigger one?
Old Mar 25, 2003 | 03:13 AM
yeah it is kinda small...sorry bout that...here's the link of the one i edited...i'm running on 56K so it'll take forever to upload...
this one isnt any better, is it?
http://www.imagestation.com/picture/...e/fc72f2f8.jpg
Old Mar 25, 2003 | 03:35 AM
sho's Avatar
sho
nope, its the same size as the one you posted.
Old Mar 25, 2003 | 05:11 AM
torkcm's Avatar
How much did it cost there to get dyno'd?
Old Mar 25, 2003 | 08:39 AM
Default Re: Dyno-tune at Inline (torkcm)
it was 195 for dyno (3 pulls) and tunning...
anyone know what can cause it to drop off at around 5k like that?
Old Mar 25, 2003 | 08:42 AM
hybrid901's Avatar
What does a stock d16 normally put down?
Old Mar 25, 2003 | 09:00 AM
*Boostwerks*'s Avatar
Default Re: Dyno-tune at Inline (hybrid901)
Around 90 with no mods.
Old Mar 25, 2003 | 09:57 AM
Default Re: Dyno-tune at Inline (Bryson)
So you guys think its pretty pathetic at 3psi or is that about right? I checked all my pipes today and the pipe right before the TB was loose...tightened that up and the boost gauge hit just a tick before the 5psi mark...i cant adjust the arm thing on the wastegate anymore that 5psi right? It does pull a lot harder now with a little bit of idling problem when the car is cold...
Do you guys think i should go for a boost controller first or a turbo timer? they're about the same and the boost controller i'm looking at is the manual Turbosmart from Inline...it clicks!!!
Old Mar 25, 2003 | 10:25 AM
Mr. Softee's Avatar
3psi? what the.... what kind of wastegate setup are you running?
Also you're power flattening / lowering is because of richening up and im guessing your boost leak, its tough to say. I'd go back with a boost controller and a more stable charge pipe setup and see what happens
Old Mar 25, 2003 | 11:02 AM
Default Re: Dyno-tune at Inline (94goldjungsr)
its a greddy kit with the internal wastegate...yeah i'm def. going back as soon as i get some other things, including money ...so you think its too rich causing it to lose power?
anyone know if 5psi is the max you can adjust the wastegate arm on the greddy td04?
Old Mar 25, 2003 | 12:01 PM
Mr. Softee's Avatar
yea you dip down below 12:1 and even below 11:1. Keep it around 12:1-12.5:1 and you will make more power guarunteed...
Old Mar 25, 2003 | 12:12 PM
so you think i should lean it out more around 5k? i dont want to touch the settings cus just my luck, my car will run like crap again...5psi is pretty nice...nice peppy
Old Mar 25, 2003 | 07:34 PM
to the tizzop....
Anyone have experience with the Turbosmart mbc?
dirtySOHC's
Jun 21, 2003 11:00 PM
DDD
Mar 25, 2003 03:31 PM
BoostedSi
Jul 30, 2002 07:54 AM
BoostedSi
Jul 23, 2002 08:00 AM
