Dyno #'s inside
this is on pump gas tuned pretty safe at 18psi, also not reving it out all the way yet.
here is the setup:
https://honda-tech.com/zerothread?id=922394
here is the setup:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 »</TD></TR><TR><TD CLASS="quote">y not use more psi? ur motor is pretty built...</TD></TR></TABLE>
i will when i do my race gas tune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinitron »</TD></TR><TR><TD CLASS="quote">That's neat, we almost put down identical numbers, at the same PSI.
Only difference is my compression ratio, and smaller turbo.
well i was wanting to run lower boost for pump, but the 44mm wg i ordered got back ordered, so i just ordered a 38 for the moment, and it can't keep up. i had to pull some timing up top to bring the power level down.
VTECJUN
64
Oct 28, 2005 10:58 PM
ActiveAero
May 8, 2003 10:22 AM
