dyno results!
Old Mar 17, 2013 | 06:59 PM
Freshdot's Avatar
Default dyno results!
Got tuned friday at evan's here's the result.
z6 on an 18G @ 18psi. HP was consistent with each pull, I believe the highest we saw was 337/270lb before things warmed up.
I've been dealing with coolant lines failing around the thermostat/intake manifold area, but overall everything is great. Haven't seen anything abnormal going on with the coolant overflow tank, maybe slightly more fill than a stock car would produce.
Car runs really smooth, and the powerband is good and linear. Wheelspin is under control quite well through 1st and 2nd on my proxes 4's. wastegate pressure in 1st @11psi and 2nd sees around 13-15.
Old Mar 17, 2013 | 07:15 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Re: dyno results!
Nice graph you have there
Old Mar 17, 2013 | 07:23 PM
Freshdot's Avatar
Thanx man! You know, I was just looking at some of the graphs for other D's he's tuned with larger turbos and better manifolds, and a tad more power..and I was thinking the same damn thing as you..unless i'm being trolled lol, it would seem this turbo outperforms the other setups in terms of full spool/rpm and holding tq to redline. Bear in mind this is on a internal wastegate and edelbrock cast mani.
Old Mar 18, 2013 | 03:21 AM
mrbigg9032's Avatar
What was timing at 18psi?
Old Mar 18, 2013 | 08:14 AM
Freshdot's Avatar
I'm not really sure where to even look in my maps to answer that question.
Old Mar 18, 2013 | 08:42 AM
Muckman's Avatar
Moderator in Chief
Not to mention looking up table timing values aren't the same as total timing. Thats a loaded question.
Old Mar 18, 2013 | 09:07 AM
Freshdot's Avatar
Can I get some opinions on retarding ign timing per psi in a boost table? I've emailed jeff and waiting for a reply. Just thought I'd get a general idea on this, the coolant pressures are leaving me concerned.
Old Mar 18, 2013 | 10:10 AM
Freshdot's Avatar
couple shots from the day.
Old Mar 18, 2013 | 10:38 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
What is going on with your sunroof? Is the roof all smashed in or what have you?
Old Mar 18, 2013 | 10:45 AM
Freshdot's Avatar
i fell victim to a hood latch issue about 2yrs ago, hence the black hood as well. getting all these things touched up before the season really kicks off along with a new set of wheels/tires.
currently on these things:
looking to do a set of 6UL's with 225/45 R888's or RA1's.
Old Mar 18, 2013 | 11:09 AM
LightningTeg's Avatar
Community Builder
NT01's are the same compound as those tires and are a bit cheaper just FYI
Old Mar 18, 2013 | 12:07 PM
Freshdot's Avatar
Thanx for the headsup brotha, I have a tire wholesaler I deal with getting me the toyo's for about $125 a piece. I'm more partial to the toyo brand, that's all I've ever run.
Old Mar 18, 2013 | 12:54 PM
Natural Aspirations's Avatar
Very nice!
Old Mar 18, 2013 | 01:45 PM
SiRCiviC94's Avatar
stock or built?
Old Mar 18, 2013 | 01:54 PM
TheShodan's Avatar
Moderator
Originally Posted by SiRCiviC94
stock or built?
oh no.. those D-series can't do even 220whp stock without a rod snapping. So he put in some work on internals for that 18G for that boost pressure level.
Old Mar 18, 2013 | 03:12 PM
Freshdot's Avatar
stock or built?
Head:
- bisimoto 2.4
- bisimoto springs + retainers
- supertech black nitride valves
- AEM cam gear
- head milled, new seals + bronze guides
- oem intake manifold
Block:
- CP 9.0:1 pistons .020" over
- Scat Rods
- Clevite bearings
- ARP studs
- Decked
Fuel:
- RC 750's
- walbro 255
- AEM FPR + Fuel Rail
Turbo:
- Greddy 18G
- Edelbrock cast manifold
- 10psi turbosmart internal wastegate actuator
- ATP 3" Vband outlet
- Custom 3" downpipe
- 3" exhaust to vibrant street power, no cat
- HKS SSQV
Transmission:
- Synchrotech full rebuild kit
- Competition stage 4 cermamic
- Competition ultra light flywheel
MISC:
- Hondata s300 + 4 bar MAP + PWM boost by gear
- All seals and gaskets replaced
- Gates racing timing belt
- Honda oil pump, water pump, tensioner
- Mishimoto radiator
- Hasport 70A mounts
Both Jeff and I were really impressed by the way this new turbosmart actuator performs, it's a new item to the market..no spike, creep, or jagged powerband.
Old Mar 18, 2013 | 03:36 PM
TheShodan's Avatar
Moderator
I love the turbosmart Internal Gates. I use those as upgrades now for the GT2860RS, GT2871R, and GT30R upgrades
Old Mar 18, 2013 | 03:53 PM
Freshdot's Avatar
seriously dude, as soon as i took it out of the box i was like "oh yes, this is what i've been missing!"
Old Mar 18, 2013 | 06:18 PM
jdmsas's Avatar
hell yea!!! deff some good numbers!! i plain to make some good numbers for my cute D as well LOL
Old Mar 19, 2013 | 04:51 AM
blackeg's Avatar
definitely a nice graph. flat tq too. how is it with that gearing upon upshift? fall out of boost at all? im sure you can pull at least a few hundred more rpm out of it if needed. curious to know timing values myself..
Old Mar 19, 2013 | 04:53 AM
TheShodan's Avatar
Moderator
Nah, his rpms seem fine. It wouldn't yield anymore power from that turbo, I can see from his graph and that setup. Steady increase, no drop off. Not bad for 41lbs/min.
Old Mar 19, 2013 | 07:59 AM
Freshdot's Avatar
my redline is set to 7,800..7,400 is where he has the shift light coming on in my cluster via s300. In between shifts I'm right where the meat and potato's live, the car literally just keeps pulling and pulling. I can honestly "feel" this graph as I'm driving.
after doing a bunch of homework I can begin to see why anything beyond a t3/t4 is too much turbo for this motor, in the street anyway. this 30r graph makes me cringe for example:
Old Mar 19, 2013 | 09:09 AM
TheShodan's Avatar
Moderator
I'm currently working on something for the 41lbs/min club outside of the usual T3/T04E realm. stay tuned.
Old Mar 19, 2013 | 11:42 AM
Freshdot's Avatar
let me know dude, i'd definitely be interested in something you produce..maybe i'll FINALLY cave and go mini ram/external hahaha.
Old Mar 19, 2013 | 11:49 AM
TheShodan's Avatar
Moderator
I may also be internal as an option.
