dyno result precision sc44
Old May 29, 2003 | 12:18 PM
b18cTurbo's Avatar
Default dyno result precision sc44
run where made at 21-22 psi
setup:
b18c5
stock sleeves
stock head
eagle rod
gsr 9:1 je piston whit honda ring
turbo precision sc44 60 trim 63 a/r
inlinepro manifold
big i/c
gsr camshaft
3" downpipe exaust
so this good or bad number for that turbo?
Old May 29, 2003 | 12:20 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: dyno result precision sc44 (sleeper007)
damn what happend at 5500?
What your fuel management.
422whp at 21psi
9:1
not to bad .
I know a guy making 377whp and 232 at 9psi .
At 21psi hes looking for 575-590ish
Old May 29, 2003 | 12:21 PM
Cyber ITR's Avatar
**** yeahhhhhhhhhh !!!!!!!!!!!!!!!!!
Old May 29, 2003 | 12:22 PM
b18bturbo's Avatar
Default Re: dyno result precision sc44 (HybridcivicLS-T)
not too bad at all
Old May 29, 2003 | 12:28 PM
b18cTurbo's Avatar
Default Re: dyno result precision sc44 (b18bturbo)
i had an ignition cut dont know y
Old May 29, 2003 | 12:29 PM
Hayasa15's Avatar
so what happened at 5500 rpm?
Old May 29, 2003 | 12:37 PM
boosted hybrid's Avatar
Those are very good results for the 60 trim compressor. Your in the efficiency range of the compressor map, and by the looks of it you have a nice powerband to go along with it. If you had more work put into the head/exhaust manifold/intake manifold you would have had far greater results. For your set-up the #'s are pretty much standard.
Old May 29, 2003 | 12:40 PM
b18cTurbo's Avatar
Default Re: dyno result precision sc44 (Hayasa15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hayasa15 &raquo;</TD></TR><TR><TD CLASS="quote">so what happened at 5500 rpm?</TD></TR></TABLE>
like i said up there was an ignition cut or something like that
what kind of trap speed in 1/4 im looking for ?
car weight 2900 lb whit me in
Old May 29, 2003 | 12:42 PM
bretx0r's Avatar
id say yoll trap in the low 120's on a good run.
Old May 29, 2003 | 12:45 PM
95c1v1cs1's Avatar
Default Re: dyno result precision sc44 (bretx0r)
low 120's is about right.
Old May 29, 2003 | 01:05 PM
done's Avatar
Default Re: dyno result precision sc44 (95c1v1cs1)
im kinda disappointed, but impressed....
That doesnt seem like useable horsepower for street (not that im saying your car is a street car if it isnt).. im just generally speaking, about your setup and your sc44..
I was execpting the turbo to spool much quicker.. and 22 psi is alot..
stock sleeves and gsr pistons? 8.8:1 compression? thats impressive...
overall thumbs up.. pretty nice..
t616
Guest
Posts: n/a
hmm makes me wonder what type of #'s i can pull off with my 44
Old May 29, 2003 | 01:24 PM
niedejb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">What your fuel management.
I'm curious too.
Old May 29, 2003 | 01:30 PM
DLB1994's Avatar
Default Re: dyno result precision sc44 (niedejb)
i want numbers like that but dam thats a laggy turbo
Old May 29, 2003 | 01:33 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: dyno result precision sc44 (DLB1994)
Nice A/F curve, err uhh lack there of.
Old May 29, 2003 | 01:42 PM
DIRep972's Avatar
Smarter than you
ok 2 things.
first off. those #'s are great for a 60trim @ 22llbs. The turbo is good for close to 30psi so u still have more room for more pressure and more power. Alot of people are scared to run high pressure but as long as its in the efficiency range it should be ok. this is what i like about the 60trim vs. the 60-1, a 60-1 may make more power @ 22lbs but it tops out @ 24-26psi where as the 60trim can keep making power @ close to 30.
2nd. as for the lag. how can u guys tell the lag if there is no torque curve?
the powerband looks really nice to me but the a/f looks a little lean. is that 12.8:1 i have trouble reading those types of graphs.
Old May 29, 2003 | 01:55 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: dyno result precision sc44 (DIRep)
Nice job man
Old May 29, 2003 | 01:59 PM
b18cTurbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep &raquo;</TD></TR><TR><TD CLASS="quote">ok 2 things.
the powerband looks really nice to me but the a/f looks a little lean. is that 12.8:1 i have trouble reading those types of graphs.</TD></TR></TABLE>
yes im a litle lean a/f are in the 12.4-12.6 range but my egt was in the cool side 760-780 range max at wot
my sc44 hit full boost around 4000 it was at 8 psi then switched to high boost whit my remore switch(profec b) around 5000 rpm
i dont have a standalone and i have my own receipe for my fuel managment
i have a msd btm for my timing control
Old May 29, 2003 | 02:05 PM
b18cTurbo's Avatar
my old dyno whit smaller i/c the only thing i changed:
Old May 29, 2003 | 02:22 PM
lsvtecvx's Avatar
what intercooler did u have, and what do u have now
Old May 29, 2003 | 03:02 PM
95c1v1cs1's Avatar
Default Re: dyno result precision sc44 (lsvtecvx)
those are respectable numbers for a 60 trim. i put down 406 at 18psi. I have pretty much the same setup.
Old May 29, 2003 | 03:42 PM
B18Flip's Avatar
Wow, makes me want to see where i can take my sc34 and stock gsr sleeves
Old May 30, 2003 | 02:33 AM
SiR Kid's Avatar
New User
Default Re: dyno result precision sc44 (B18Flip)
Yeah, seriously... Why do I get the feeling that 232 I made on my little 46 trim is going to be a REALLY low number compared to my SC34!
I'm REALLY getting excited that this thing will be running again soon....
NICE numbers, BTW. I'd love to make that kinda power.
XEek4
Jun 19, 2006 07:09 AM
Antilag
Jun 5, 2005 08:12 PM
tony1
Feb 19, 2005 06:01 AM
TurboTegB18c
Jan 21, 2005 05:04 AM
servion
Aug 14, 2004 01:29 AM
