DYNO: E85, GT2871r, 84mm gsr, b16head
#27
Re: DYNO: E85, GT2871r, 84mm gsr, b16head (VRD)
shane at db performance. he is the only person around here (mn) that i trust to tune now. And that comes from experience.
#30
Re: DYNO: E85, GT2871r, 84mm gsr, b16head (batboyvaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj »</TD></TR><TR><TD CLASS="quote">shane at db performance. he is the only person around here (mn) that i trust to tune now. And that comes from experience. </TD></TR></TABLE>
is this shanes first time tuning neptune??? i noticed that he became a neptune tuner/dealer not too long ago...
#32
Re: (cotorresgee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cotorresgee »</TD></TR><TR><TD CLASS="quote">What did you change on your stock fuel system? I have been debating on running this fuel oh yeah what injectors you run?</TD></TR></TABLE>
i'm running a walbro and 1000cc's everything else is oem
#35
Any of you know how these people are getting such a flat tq curve with the same turbo? Here are some dyno's. Is the magic number of boost 24psi or something?
http://forums.evans-tuning.com...2871r
#36
Nice powerband man, I think its a great choice for hpde and autocrossing. I had a question though, do you know what the injector duty cycle was at the end of you tune? Ive been thinking about E85, but dont know what it will max out at with the same fuel components as you.
#37
Re: DYNO: E85, GT2871r, 84mm gsr, b16head (chubz0r)
put the 82a/r turbine on it.. its pretty cheap and will help keep the tq flat instead of it dropping off like it does. it wont hurt spool much at all
#43
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chubz0r »</TD></TR><TR><TD CLASS="quote">Nice powerband man, I think its a great choice for hpde and autocrossing. I had a question though, do you know what the injector duty cycle was at the end of you tune? Ive been thinking about E85, but dont know what it will max out at with the same fuel components as you. </TD></TR></TABLE>
i'm not sure on the duty cycle but here is a snap of my high cam fueling map.
I think the injectors were setup at 720cc but I am running 1000's
#44
1 Post
You are going to be making too much for 1000s...you need 1600s and a Big Pump.
#45
Re: DYNO: E85, GT2871r, 84mm gsr, b16head (Suprdave)
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">
You are going to be making too much for 1000s...you need 1600s and a Big Pump.</TD></TR></TABLE>
Well theres my answer.
Thanks.
#46
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj »</TD></TR><TR><TD CLASS="quote">Any of you know how these people are getting such a flat tq curve with the same turbo? Here are some dyno's. Is the magic number of boost 24psi or something?
Their curves are flatter because they are making less torque and maintaining that lower number flat across the powerband. You are making higher torque and probably maxing out the flow of the turbo at high rpm so the torque drops off to the same lower peak number as theirs at the end. The flat torque curve looks better, but look at the actual torque numbers at each rpm. You have more low end, midrange, and a larger area under the curve. Lay their graphs on top of yours and yours will look better, imo.
#48
Re: (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj »</TD></TR><TR><TD CLASS="quote">yes it was his first time. it is a very easy system to tune</TD></TR></TABLE>
So no fuel rail or FPR?? Damn if thats the case then, I bought those for nothing.
#49
Re: (HiProfile)
Corect me if I'm wrong, but didn't he previously state he was running the T3 .63 housing? IMO, that car is in it's peak, and should be plenty ( more then enough) for what you want to do with it.. Work on suspension, and getting that dialed in.
if you do indeed, plan to make it a street/track day/autocross car.
supermex
Honda Civic (2001 - 2005)
12
06-05-2007 03:33 AM
