dumb questions
Old Mar 2, 2002 | 07:31 PM
vtecsiqt's Avatar
Default dumb questions
what does cel stand for.......what is open/closed loop operation
Old Mar 2, 2002 | 08:04 PM
HXMan's Avatar
Default Re: dumb questions (vtecsiqt)
CEL=Check engine light.
When in reference to ECU:
open loop means the ecu is correcting fuel injection based on O2 sensor reading.
closed loop....not using O2 sensor.
In regard to turbo setup:
Open loop- wastegate vents to atmosphere directly
Closed loop- wastegate vents into dump tube that goes back into exhuast, usually before the catalytic converter.
Old Mar 3, 2002 | 12:46 PM
dbman96's Avatar
New User
Default Re: dumb questions (HXMan)
That's right except you got closed and open loop fuel operation backwards.
Closed loop means the fuel injection is controlled based on feedback from the O2 sensor.
Open loop means the fuel is being controlled by a predefined map with no feedback.
Old Mar 3, 2002 | 12:54 PM
98Psi ITR's Avatar
Default Re: dumb questions (dbman96)
jarrYd
Mar 16, 2007 05:27 PM
Perfectionist
Oct 8, 2006 02:00 PM
the soL that could
Feb 17, 2006 09:27 AM
Stew Pidasso
Nov 18, 2003 05:27 AM
