DSM Injector Install
Old Mar 18, 2004 | 07:28 PM
Sassafrass's Avatar
Default DSM Injector Install
I want to get a set of DSM injectors to put on my turbo setup, its a 99 LS motor in a 93 DX hatch. Car is still obd1 wasnt rewired or anything.
So exactly how hard is the install, are there other parts needed to complete this? if so how much?
Old Mar 18, 2004 | 08:32 PM
ITSTOCK's Avatar
Default Re: DSM Injector Install (Sassafrass)
They are very easy to install. You have to bore out the injector seals in the intake manifold slightly with a dremel. You also have to use a resistor box or wire i some resistors. If you do a search there isplenty of info on this topic.
Old Mar 18, 2004 | 08:45 PM
turboteg2nv's Avatar
check this link out:
http://www.homemadeturbo.com/t....html
I figure i should help rather then tell you to search.
Old Aug 29, 2004 | 05:40 AM
Curtis2kul's Avatar
Default Re: DSM Injector Install (turboteg2nv)
did you remove the intake manifold when you bored out the injector seals
Old Aug 29, 2004 | 06:11 AM
danl's Avatar
Banned
Default Re: DSM Injector Install (Curtis2kul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curtis2kul &raquo;</TD></TR><TR><TD CLASS="quote">did you remove the intake manifold when you bored out the injector seals</TD></TR></TABLE>
No, the seals pull out. The link to homemade turbo explains it very well.
97turboteg
Apr 20, 2006 01:20 PM
integrx
Dec 19, 2003 05:41 AM
airwalk07143
Dec 3, 2003 07:37 PM
b20turbojason
Sep 24, 2003 07:21 PM
TurboJesse
Sep 17, 2003 04:56 PM
