dsm injector- do i need injector box
Old Feb 2, 2005 | 06:23 PM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
Default dsm injector- do i need injector box
from what i heard i will need an injector box for my 450's because i injector is saturated and the other is peak and hold. is this true. if so how much are they?
Old Feb 2, 2005 | 06:29 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: dsm injector- do i need injector box (h22boy)
yes, you need a resistor box. price can range from free to like 25 bucks. i got mine for 8 shipped.
Old Feb 2, 2005 | 06:38 PM
SOHC_MShue's Avatar
yes you will need one. Or you can use 4 inline resistors....
Old Feb 2, 2005 | 06:40 PM
TheShodan's Avatar
Moderator
The DSMs are 450cc Peak and hold and have a different voltage than the Honda ones. An injector box or resistors are required for this injector or any peak and hold.
Old Feb 2, 2005 | 06:41 PM
splitime's Avatar
Hold up guys... lets get more car info. He has h22... he might be peak/hold already and have a resistor box..
Just like to be safe and get all the info before telling him to buy something
Old Feb 2, 2005 | 06:42 PM
BlueShadow's Avatar
Default Re: dsm injector- do i need injector box (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">yes you will need one. Or you can use 4 inline resistors....</TD></TR></TABLE>
Yup what he said, if you decide to do it this way you can use four 10 watt 10 ohm resistors (1 for each injector). You can get these at any Radio Shack.
Old Feb 3, 2005 | 10:56 AM
jdm-ray's Avatar
Default Re: dsm injector- do i need injector box (splitime)
to tell you the truth i dont know if im peak and hold already. they are stock injectors, stock 94 h22.
Old Feb 3, 2005 | 01:21 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22boy &raquo;</TD></TR><TR><TD CLASS="quote">to tell you the truth i dont know if im peak and hold already. they are stock injectors, stock 94 h22. </TD></TR></TABLE>
Well if you are using stock 94 injectors that means they are peak and hold. Did you do your own install or did somebody else do it?
Do you see a resistor box connected to your injectors or something?
Old Feb 3, 2005 | 01:55 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22boy &raquo;</TD></TR><TR><TD CLASS="quote">to tell you the truth i dont know if im peak and hold already. they are stock injectors, stock 94 h22. </TD></TR></TABLE>If you are still unsure, take one of them out and check it with a multimeter (OHM). Check the ohm resistance between the two metal tabs. If the reading is around 2.4ohms = low impedance (Peak and hold type) .... if it reads 10-12ohms = high impedance (saturated type)
Old Feb 3, 2005 | 04:09 PM
HRC69's Avatar
Default Re: dsm injector- do i need injector box (NVturbo)
Thank you NVTurbo, I've been looking for away to tell the difference b/t injectors.
Old Feb 3, 2005 | 07:01 PM
jdm-ray's Avatar
they are stock injectors and no the turbo is not in my car yet but will be in a couple weeks. so now that i know my stock ones are peak and hold ill just buy a resistor box. thanks.
Old Feb 3, 2005 | 08:54 PM
JRciv's Avatar
Default Re: (h22boy)
Here's a badass link for you guys to use in the future:
http://www.robietherobot.com/s...e.htm
Old Feb 3, 2005 | 09:00 PM
This One's Avatar
Default Re: (JRciv)
if you have a Swapped chassis w/ the H22 someone should have already put in the resistor box if you have stock h22 injectors.
if you have a prelude or accord you should already have the resistor box
Old Feb 4, 2005 | 06:16 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: dsm injector- do i need injector box (HRC69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HRC69 &raquo;</TD></TR><TR><TD CLASS="quote">Thank you NVTurbo, I've been looking for away to tell the difference b/t injectors. </TD></TR></TABLE>You're welcome... Try to use this way of checking in case someone is trying to sell you some injectors that you have doubts on (whether being P/H or saturated).
shuttle xer
Northeast (Sales)
Aug 24, 2006 12:05 PM
RACEPAK
Jul 20, 2005 12:40 PM
Licensed2Spool
Apr 12, 2003 10:51 AM
