dsm 450cc work with hondata???
Old May 8, 2002 | 09:17 AM
tararan's Avatar
Default dsm 450cc work with hondata???
i got a dsm 450cc injectors, will be doin the afc trick for a lil bit. then standalone later on this year or early next year.
would the DSM 450cc injector work with the hondata?? also using the resistor box.. thanks.
Old May 8, 2002 | 09:26 AM
Sonny's Avatar
Default Re: dsm 450cc work with hondata??? (tararan)
Yes, it will work fine. I used that setup with great success. You will need RC/OBD1 injector clips to use those injectors if your car is 96 or later (OBD2). E-mail me if you need a set.
Sonny
Old May 8, 2002 | 09:38 AM
tararan's Avatar
Default Re: dsm 450cc work with hondata??? (Sonnyballs)
actually i already got a set of injector clips.. got it from a gem storm, i just need to put it on... can you help me install the resistor box please... which wire on the injector do i need to connect on which side of the resistor box... my resistor box got 5 wires.. 4 black wires and 1 red... thanks
Old May 8, 2002 | 09:42 AM
Sonny's Avatar
Go here:
http://www.hondata.com/cgi-bin/yabb/...num=1012601012
Sonny
Old May 8, 2002 | 10:42 AM
tararan's Avatar
thanks man, that helps a lot...
95dc2teg
Jul 29, 2006 11:01 PM
yodas-gsr
Oct 24, 2005 01:41 AM
DD_JonnyLee
Feb 26, 2003 05:14 PM
boostaholic
Nov 30, 2002 02:04 AM
