Are DSM 440's overkill for 7lbs boost?
Old Dec 19, 2002 | 01:49 PM
b18cya's Avatar
Default Are DSM 440's overkill for 7lbs boost?
an SMC or Vafc, are 440's overkill for a 7lb turbo setup on a stock gsr motor? thats what i've been planning, & a well respected turbo guy said that he's tried to tune the same setup & was running waay too rich.
he suggested getting some dsm 390's or smaller with a vafc.
any suggestions, comments???
Old Dec 19, 2002 | 01:51 PM
b18bturbo's Avatar
Default Re: Are DSM 440's overkill for 7lbs boost? (b18cya)
they should be fine just tune it out and you should be okay give you some room to improve as well. much better than fmu setup with stokc injectors
Old Dec 20, 2002 | 08:58 AM
b18cya's Avatar
Default Re: Are DSM 440's overkill for 7lbs boost? (b18bturbo)
ttt
Old Dec 20, 2002 | 12:17 PM
TeStUdO's Avatar
it should work fine zip is comin out with the smc+ that will let you lean or richen every 1k rpms. for the price compared to a vafc you cant beat it. and dsm's are 450's you need to run them with a resistor box or in line resistors.
Old Dec 20, 2002 | 01:01 PM
wickedxboi's Avatar
Default Re: Are DSM 440's overkill for 7lbs boost? (00si5)
when will the smc be released? does anyone know?
Old Dec 20, 2002 | 01:06 PM
MiraiZ's Avatar
Default Re: Are DSM 440's overkill for 7lbs boost? (wickedxboi)
nothing is really overkill....think of it as added safety
Old Dec 20, 2002 | 01:25 PM
evoeone's Avatar
Default Re: Are DSM 440's overkill for 7lbs boost? (MiraiZ)
i agree that it might not be overkill, but your stocks might possibly do, idle might run rich tho
Old Dec 20, 2002 | 01:30 PM
HXMan's Avatar
They are what I would get. Stock injectors are only 240cc.
Old Dec 20, 2002 | 01:35 PM
evoeone's Avatar
Default Re: Are DSM 440's overkill for 7lbs boost? (HXMan)
well my 190cc runs rich at 9 psi, and could do more on my car, some VW's run fine at 15-17 psi on stocks all day with FMU only!!! or stand alone
VW 1.8T's use 240's and run 18 psi all day long
i'm just using these examples as comparisons of boost to injector size kind of ratio
its probably how you tune it
Old Dec 20, 2002 | 01:51 PM
PressurizedSi's Avatar
Default Re: Are DSM 440's overkill for 7lbs boost? (evoeone)
The SMC is already out. You can buy it here: http://www.diabloautosports.com/
Old Dec 20, 2002 | 01:52 PM
Cramerox's Avatar
hey man this is a honda board heheh jk......i think the 440's are fine. Might also depend if your going to run an intank pump or inline.
Old Dec 20, 2002 | 01:54 PM
blufke's Avatar
Default Re: Are DSM 440's overkill for 7lbs boost? (PressurizedSi)
he is referring to the smc plus that has 1k adjustments, not the regular smc.
Old Dec 20, 2002 | 02:05 PM
b18cya's Avatar
Default Re: Are DSM 440's overkill for 7lbs boost? (blufke)
there are no other fuel mods. just the larger injectors & a piggyback computer.
Old Dec 20, 2002 | 05:48 PM
see2k's Avatar
they need to upgrade that web page.. they still have the picture of the SMC and my god that price went up!
Plus its not describing the SMC correctly. Hopefully this version will make my car start
franklude
Jun 8, 2005 11:56 AM
riddickone
Nov 23, 2003 06:38 PM
iam7head
Mar 9, 2003 12:39 AM
b18cya
Feb 24, 2003 07:55 PM
legendboy
Jul 11, 2002 07:27 AM
