Drilling & tapping of stock pan??
Old Jan 10, 2006 | 09:02 AM
j_fukin_t's Avatar
Default Drilling & tapping of stock pan??
I'm going boost here soon and i need to know where exactly i should drill in the factory b16 pan, i know if its too low it causes oil back-up and essentially trashing the turbo and same to be said if its too high?? any help greatly appreciated FYI: i'm going w/ a greddy bolt on kit
Old Jan 10, 2006 | 09:14 AM
Jared's Avatar
dont try to tap the factory pan, its too thin
Old Jan 10, 2006 | 09:31 AM
j_fukin_t's Avatar
Default Re: (Jared)
whats my alternative then?? i honestly don't want to have to shell out 300+ for the moroso (which would be nice)
Old Jan 10, 2006 | 09:43 AM
BoOsTeD C1's Avatar
tap the factory pan...im on my oem pan with no probs...you can doo ittttttt!!!
Old Jan 10, 2006 | 09:53 AM
Jared's Avatar
Do it right and weld in a fitting.
Old Jan 10, 2006 | 09:57 AM
Joseph Davis's Avatar
Default Re: (Jared)
I've used AN bulkhead fittings with great success.
Old Jan 10, 2006 | 10:16 AM
vaporboy12's Avatar
Default Re: (J. Davis)
on all the cars ive done ive put a 12an in the pan grinded the back side of the fiiting to be flat with the pan weld inside around the fitting grind down and then weld the outside of the pan were the fiiting is
Old Jan 10, 2006 | 10:23 AM
Hybrid96EK's Avatar
Default Re: Drilling & tapping of stock pan?? (j_fukin_t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_fukin_t &raquo;</TD></TR><TR><TD CLASS="quote">I'm going boost here soon and i need to know where exactly i should drill in the factory b16 pan, i know if its too low it causes oil back-up and essentially trashing the turbo and same to be said if its too high?? any help greatly appreciated FYI: i'm going w/ a greddy bolt on kit </TD></TR></TABLE>
I have NEVER heard of issues resulting from putting the fitting "too high" on the pan.
Old Jan 10, 2006 | 12:13 PM
j_fukin_t's Avatar
Default Re: (VTEC_pWrD_CiViC)
how high do i want to go w/ the fitting?? i can have a buddy of mine weld it on both sides so thats not a prob, anyone wanna measure theirs for me??
Old Jan 10, 2006 | 12:33 PM
stealthmode62's Avatar
Default Re: (j_fukin_t)
It's not an answer anyone can give you. Put your manifold/turbo on and then from there you'll be able to see which spot on the pan is optimum for your setup. Tapping the pan before seeing how everything is going to setup is a bigger risk than it has to be.
Old Jan 10, 2006 | 05:31 PM
Default Re: (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote">Tapping the pan before seeing how everything is going to setup is a bigger risk than it has to be. </TD></TR></TABLE>
Yup, I set up my oil drain based on how the turbo + mani combo sat. When I went to install it into my car, the new crossmember didn't like that so much.
Old Jan 10, 2006 | 06:01 PM
j_fukin_t's Avatar
thanks for the advice, i can see where that would be the wise choice, thanks again
Old Jan 10, 2006 | 07:34 PM
black98gsr-t's Avatar
if it is a complete greddy kit it will come with parts for the oil pan and a template for the pan... the template will tell u how to mount it.... i have a greddy kit and used the drain fitting it came with and did not have to weld anything and no leaks for 1 1/2 yrs... so far...
Old Jan 10, 2006 | 07:43 PM
Hybrid96EK's Avatar
Default Re: Drilling & tapping of stock pan?? (black98gsr-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black98gsr-t &raquo;</TD></TR><TR><TD CLASS="quote">if it is a complete greddy kit it will come with parts for the oil pan and a template for the pan... the template will tell u how to mount it.... i have a greddy kit and used the drain fitting it came with and did not have to weld anything and no leaks for 1 1/2 yrs... so far...</TD></TR></TABLE>
It shouldn't leak assuming you don't bend the **** out of the pan when drilling it. I think the problem is most people don't support the pan correctly when drilling and bend it. This creates an area for it to leak. Its just alot more "fool proof" I think to weld it. Then there are no risks involved, you know?
Old Jan 12, 2006 | 08:49 AM
j_fukin_t's Avatar
Default Re: Drilling & tapping of stock pan?? (Hybrid93Eg)
yea as long as they are a good welder (which he is)
TurboEM1
Aug 27, 2007 02:42 AM
DrSeuss
Jun 20, 2007 06:34 PM
huntarrr
15
Mar 15, 2006 08:36 AM
EJ8 GSR-T
11
Jan 3, 2006 08:34 AM
taejin11
Welding / Fabrication
Sep 30, 2004 02:50 PM
