Drag Manifold ?
Old Feb 5, 2008 | 03:28 AM
hawkturbo's Avatar
Default Drag Manifold ?
hello this manifold is good to handle 350 hp Thanks
Old Feb 5, 2008 | 03:58 AM
Joseph Davis's Avatar
Default Re: Drag Manifold ? (hawkturbo)
You wouldn't be the first to go there with one.
Old Feb 5, 2008 | 05:22 AM
ATYPR's Avatar
yes
Old Feb 5, 2008 | 06:14 AM
hawkturbo's Avatar
Default Re: Drag Manifold ? (ATYPR)
thanks man but why the wastegate is only for two pistons
Old Feb 5, 2008 | 07:26 AM
DRIVENRacing's Avatar
?? do you know the purpose of the wastegate?
Old Feb 5, 2008 | 10:25 AM
hawkturbo's Avatar
Default Re: (DRIVENRacing)
yea
Old Feb 5, 2008 | 10:27 AM
hawkturbo's Avatar
ok other ?? how much lbs of turbo can hold this pls tell me the gud things an bad things of this manifold thanks sorry for my inglish
Old Feb 5, 2008 | 10:44 AM
95dc2teg's Avatar
Default Re: (hawkturbo)
since the drag manifold is made of cast iron, its not going to have a problem holding the weight of a bigger turbo. The only problem that you would have is if the turbo is too big, because it wont fit it and will be hitting the block. Weight wise though, no problem....
Old Feb 5, 2008 | 10:45 AM
95dc2teg's Avatar
Default Re: (95dc2teg)
the wastegate placement is poopy too because its only placed off of one runner. I would atleast go with a rev hard (wastegate placed off two runners) or even better a mutek or blox manifold (wastegate placement in the center).
Old Feb 5, 2008 | 04:46 PM
hawkturbo's Avatar
sorry man but i dondt understand
(The only problem that you would have is if the turbo is too big, because it wont fit it and will be hitting the block. Weight wise though, no problem....)
i have a GT32 garret turbo for this manifold and a want run 20 psi max
Thanks for the help
Old Feb 5, 2008 | 06:37 PM
95dc2teg's Avatar
i talking about if you get a huge turbo. Your gt32 will work fine. Im assuming u want to keep ac and ps?
Old Feb 6, 2008 | 03:21 AM
hawkturbo's Avatar
yea i want
Old Feb 6, 2008 | 08:35 AM
top end tuner's Avatar
yeah it will work fine, if your keeping ac and power steering your just gonna have to grind down some of the webbing from the block, doesnt hurt it. its a good manifold for first time setups but i recommend the blox or mutek or inline pro manifold because of crappy wategate placement
eVo05
Sep 25, 2006 08:06 PM
AlpineIntegra01
Aug 17, 2005 07:02 PM
2.2
Sep 17, 2002 07:13 AM
boosted3g
Dec 7, 2001 02:17 PM
