drag kit turbo sizes
Old Jun 25, 2002 | 07:37 PM
Mr. Softee's Avatar
Default drag kit turbo sizes
what size turbo does the DRAG kit come with for a GSR or ITR?
Anyone know?
thanks
-sam
Old Jun 25, 2002 | 07:38 PM
GSRwBOOST's Avatar
Default Re: drag kit turbo sizes (94goldjungsr)
T4/T3 and most of the time a .63 something or other.. and not sure what the other thingy measures out at.... the compressor houseing thing i dont think makes a difference... ??
But the answer to your question is..
yes
Old Jun 25, 2002 | 07:48 PM
Mr. Softee's Avatar
Default Re: drag kit turbo sizes (GSRwBOOST)
can anyone else confirm this
Old Jun 25, 2002 | 07:56 PM
TurboITR's Avatar
t3/t4e .54 a/r for the gsr/itr
t3/t4e .50 a/r for the civic si
t3/t4b for the ls
i believe they use a 63 exhaust for all DOHCs
as far as the SOHC turbo kits go i dont know...
[Modified by TurboITR, 11:57 PM 6/25/2002]
Old Jun 25, 2002 | 08:00 PM
integra-modder's Avatar
the kit im getting: DRAG Gen III
Here are the kit specs:
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 TO4E High flow turbocharger assembly
Turbonetics Deltagate Mark II Wastegate (7 PSI Spring)
Greddy Type S Blow off valve
Drag mandrel bent high flow chrome plated pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegaste dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator
Intake air filter assembly
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All nessasary hardware and fittings
All nessassary hose and hose clamps
All nessassary gaskets
Old Jun 25, 2002 | 08:04 PM
quikrpm'z's Avatar
Default Re: drag kit turbo sizes (TurboITR)
t3/t4b for the ls
what would be the difference between these two?
Old Jun 25, 2002 | 08:53 PM
TurboCivicSi's Avatar
Default Re: drag kit turbo sizes (quikrpm'z)
dude....
Don't even worry about it..The Drag Kit freakin Rocks!!
I love my kit.. I will need to purchase the ball bearing cartridge soon, but till then I love my Kit..
I recommend Hondata to every Turbo Honda out there..
See ya,
-Jason
Got traction
Jul 8, 2008 07:22 PM
Turbo-Honda
Apr 25, 2004 03:51 AM
99integ
Jul 31, 2002 05:05 PM
Double 06
Jul 10, 2002 01:35 PM
Scotty
Jun 17, 2001 05:50 PM
