DRAG GEN 3 MANI ?
Old Nov 12, 2003 | 05:28 PM
B18C1CYA's Avatar
Default DRAG GEN 3 MANI ?
i ported my wastegate opening on my drag mani today, and noticed that the hole dosent line up so good on the gasket like at least 3/16 off or so. Could this cause the notorius boost spike problem? well i havent tested it yet but has anyone else don this and if so dos it work?
Old Nov 12, 2003 | 05:41 PM
TeStUdO's Avatar
Default Re: DRAG GEN 3 MANI ? (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">i ported my wastegate opening on my drag mani today, and noticed that the hole dosent line up so good on the gasket like at least 3/16 off or so. Could this cause the notorius boost spike problem? well i havent tested it yet but has anyone else don this and if so dos it work?</TD></TR></TABLE>
The wastegate gasket?? The one between the manifold and wastegate? Just run with no gasket. As for the boost spike problem its the Deltagate wastegate and the wastegate placement on 1 cylinder that cause that.
Old Nov 12, 2003 | 06:05 PM
SpdFrk's Avatar
Default Re: DRAG GEN 3 MANI ? (TeStUdO)
Besides going with a tial wastegate and porting out the manifold, would going with a bigger size and/or open dump tube help spiking problems?
Old Nov 13, 2003 | 06:53 AM
Rory Breaker's Avatar
Default Re: DRAG GEN 3 MANI ? (SpdFrk)
I would also like to know what can be done about this.
I plan on porting the mani...I cant imagine that we are just screwed. With as many people running drag kits as there are, there has to be a solution.
Old Nov 13, 2003 | 08:55 AM
Speed PHreak's Avatar
Default Re: DRAG GEN 3 MANI ? (newgsrdriver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsrdriver &raquo;</TD></TR><TR><TD CLASS="quote">I plan on porting the mani...I cant imagine that we are just screwed. With as many people running drag kits as there are, there has to be a solution.</TD></TR></TABLE>
THere is a solution, get a different mani. Boost creep is inevitable on those mani's with a "3 exhaust. ONly soultion I could offer would be to provide some added back pressure on your exhaust(2.25~2.5" size), and run a very free flowing dump tube. Porting will hlpm but not solve the problem
Spooled1.6L
Apr 17, 2004 08:53 AM
Rah Rah
Jul 7, 2003 08:00 PM
swlabhot
Jun 6, 2003 11:21 AM
ziggity
May 9, 2003 12:16 PM
Lei Siew Long
May 12, 2002 05:43 PM
