Dra Gen 3 / CEL. Please help !!!!
Old Apr 18, 2003 | 06:07 PM
vteec's Avatar
Default Dra Gen 3 / CEL. Please help !!!!
Yesterday a couple of friends did a drag gen 3 install on a JDM ITR.
We have a couple of problems:
CEL came on after second "test run" (we resetted the ecu and everything seems fine tilll now but we're still worried)
The oil check light on the intrument panel is not coming on before the ignition as it used to. (it used to illuminate and then turn off as soon as the engine is started)
Can anyone expalain with pics if possible please, how to adjust the Tial actuator for boost please..........we connected the thin hose pipe as it comes from one end to the other of the Tial...is this at full boost ?
Thanking you,
Eric
Old Apr 18, 2003 | 07:03 PM
The Crow's Avatar
Default Re: Dra Gen 3 / CEL. Please help !!!! (vteec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteec &raquo;</TD></TR><TR><TD CLASS="quote">Yesterday a couple of friends did a drag gen 3 install on a JDM ITR.
Thanking you,
Eric</TD></TR></TABLE>
The CEL should be a map sensor code. Just check it.
I don't know what you did to make the oil light not work. Maybe you unplugged the sensor on the back of the block?
ragethemachine86
Oct 11, 2006 01:23 PM
GSR44
Jul 14, 2006 03:44 PM
krott5333
May 6, 2004 06:08 PM
