dp flange question asap
Old Nov 12, 2005 | 11:26 AM
zexifiedlude's Avatar
Default dp flange question asap
aight i got a dp that has a 5 bolt flange for the turbo, now the turbo i want to get is a 4 bolt.. now the question is, could i get the 5 bolt flange unwelded and buy another 4 bolt flange and get it welded on? kinda need to know asap, oh and also, where can i get a 4 bolt flange. thanks in advance
Old Nov 12, 2005 | 11:29 AM
turbotime's Avatar
yup.
try http://www.kteller.com not sure though
Old Nov 12, 2005 | 11:47 AM
is it expensive to unweld something and then weld almost the same thing back on
Old Nov 12, 2005 | 12:37 PM
IHaveTurbos's Avatar
well it will have to be cut off and the new one welded on, and cost is going to vary.
Old Nov 12, 2005 | 02:05 PM
D@nnY's Avatar
Default Re: (TurboElements.com)
the 4 bolt turbo housing will sit the turbo in a different place then the 5 bolt
the old downpipe may not fit and you may have to hack up your block to make the turbo fit
Old Nov 12, 2005 | 02:57 PM
^ y would it sit the turbo diffrent? the mani holds the turbo to the block, at most the mani would have to be shortnd or lenghend with the new 4 bolt flange
Old Nov 12, 2005 | 03:08 PM
D@nnY's Avatar
Default Re: (zexifiedlude)
what type of manifold is it? alot of people have problems using 4 bolt turbos ..youll see
Old Nov 12, 2005 | 03:55 PM
my bad i didnt mean the mani would have to be shortnd/lengthnd i ment the downpipe... its a log mani
boostedgsr1234
Jan 13, 2008 07:20 PM
1990si
Apr 9, 2007 05:59 AM
goofball123321
Mar 8, 2004 02:41 PM
project dc2
Dec 10, 2003 07:18 PM
Acura_I-RS
Jul 31, 2003 02:43 PM
