Downpipe Mounting Bracket?
Old Nov 3, 2001 | 07:05 PM
GruvyTune's Avatar
New User
Default Downpipe Mounting Bracket?
The stock exhaust had a mounting bracket holding the downpipe to the engine block. Is it necessary to rig one up for a turbo downpipe?
What do people normally do for stability and to prevent cracking?
I just put in a Thermal 3" and have the exhaust hanging from the hangers and then bolted to a Carsound 3" cat. That then goes to the downpipe via a flexible ball joint (custom made). Is that enough to protect the DP or does it need to be fixed in some way to the block?
Old Nov 4, 2001 | 03:26 AM
GruvyTune's Avatar
New User
Default Re: Downpipe Mounting Bracket? (GruvyTune)
Anyone?
Does everyone's downpipe just bolt right to their CAT without being secured in some way to the engine block (as is on the stock)?
Old Nov 6, 2001 | 07:27 PM
Mikex25's Avatar
New User
I just wanted to revive this thread because I was also wondering the same thing.
Old Nov 6, 2001 | 07:33 PM
TurboIntegra's Avatar
Default Re: Downpipe Mounting Bracket? (Mikex25)
I had a mufflershop make a bracket that attatches to the downpipe and anchors to a screw on the block. It cost me no more than $10.
Oh and it helps too. I know this because I was in a bad accident and everything got crused except my manifold and downpipe because I had the bracket made!
You should also have flex pipe too!
Old Nov 9, 2001 | 04:32 AM
GruvyTune's Avatar
New User
Default Re: Downpipe Mounting Bracket? (TurboIntegra)
what is everyone's else like? Do all turbo kits neglect mounting the dp to the engine block? Is it ok then to leave it like this as long as you have a flex piece in the middle?
Old Nov 13, 2001 | 04:00 PM
GruvyTune's Avatar
New User
just keeping this topic alive and hoping others will respond. I'm really curious as to whether you really need to bracket the DP to the block if the entire exhaust is suspended with hangars and there is a flexible joint inline before the CAT.
thanks!
Old Nov 13, 2001 | 06:55 PM
DeeJay's Avatar
New User
I think it would be ok, my dc headers don't have it and I've had them on for 2 years.
Old Nov 13, 2001 | 08:48 PM
Etylorcen's Avatar
Default Re: Downpipe Mounting Bracket? (DeeJay)
The downpipe on teh drag kit will come up short. You need to get something custom made to fit. I just took off my cat and ran a downpipe using a flexpipe from kragen and welded a 2.5'' 3 bolt flange welded to a 6'' of 2.5'' wide pipe then connected the flex pipe to the dp and pipe then bolted it all up then clamped em down.
Old Nov 14, 2001 | 02:32 PM
D-Man's Avatar
Default Re: Downpipe Mounting Bracket? (Etylorcen)
put a flex pipe and a bracket or two on that downpipe or your manifold will crack..only be a matter of time
Old Nov 14, 2001 | 02:43 PM
98hx99b18c's Avatar
Default Re: Downpipe Mounting Bracket? (D-Man)
Dont have one on mine, but it wouldnt hurt at all to have one on. If you got the time and resources go ahead and do it.
Mishako129
Jan 31, 2013 03:28 PM
Econo Appliance
Nov 22, 2006 12:31 AM
jdm_vtec
Nov 19, 2006 08:04 AM
vangc6780
Apr 1, 2005 07:41 AM
Elvis1977
May 1, 2004 09:09 AM
