downpipe ground clearance?
Old Apr 15, 2007 | 04:50 AM
huge230's Avatar
Default downpipe ground clearance?
What kind of clearance do you guys have from the downpipe to the ground?
Anyone have pics?
Old Apr 15, 2007 | 09:15 AM
Schister66's Avatar
Man U FTW
Default Re: downpipe ground clearance? (huge230)
I had clearance issues on my last setup w/ my 2.5" downpipe because the fabricator obviously didn't take much time slapping it together
but my new manifold and DP (listed in sig) have great clearance...the 3" dp tucks against the oil pan and has almost 0 chance of hitting the ground unless i do something stupid..
Old Apr 15, 2007 | 09:35 AM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default Re: downpipe ground clearance? (Schister66)
Lowest part on the car is the flex section i had put in on the downpipe. Im running a 2.5" downpipe and 3" exhaust but the flex section is much bigger than 3". Depends on how low your car is. If your car is slammed expect to have some clearance issues, but for the most part you should be fine.
Old Apr 15, 2007 | 09:38 AM
Schister66's Avatar
Man U FTW
if you get a manifold/dp combo from a company that is well respected for their craftsmanship, you shouldn't have to worry about clearance issues.....so basically pick from most anyone in the Marketplace and you'll be fine
jv88_dc2
Apr 29, 2014 05:05 PM
JHipps
Oct 2, 2013 02:57 AM
Will_H
Welding / Fabrication
13
May 12, 2007 01:27 PM
huge230
May 20, 2006 06:30 PM
adotlee
Mar 9, 2004 04:42 PM
