dowel pins?
Old Oct 16, 2007 | 03:59 PM
lambertincorp's Avatar
Default dowel pins?
i have no dowel pins in my ls vtec could this be a potential serious problem?
Old Oct 16, 2007 | 05:29 PM
adseguy's Avatar
Default Re: dowel pins? (lambertincorp)
How else would you know the head is on the short block perfectly straight?
Old Oct 16, 2007 | 05:40 PM
m R g S r's Avatar
Default Re: dowel pins? (adseguy)
yeahhh it could be off by a lot...nothing is there to center the head on top of the pistons, make sure it is in line for the timing belt etc. .
Old Oct 16, 2007 | 07:22 PM
Default Re: dowel pins? (m R g S r)
i have oversized head studs 1/2 and the head barely fits and there is no room 4 them i could have had it drilled out for dowels should i have or will the studs keep it straight?
Old Oct 16, 2007 | 09:19 PM
Muckman's Avatar
Moderator in Chief
Why even bother with thicker head studs if your skipping the fundamentals? To run thicker head studs you had the block drilled and retapped. So how much harder is it to have the head drilled out for larger dowels?
Old Oct 16, 2007 | 10:12 PM
bootlegcivic's Avatar
You don't have to do any machine work. Golden Eagle makes them they're cheap ($20) and you definitely need them.
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Oct 17, 2007 | 12:24 PM
Default Re: dowel pins? (bootlegcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Why even bother with thicker head studs if your skipping the fundamentals? To run thicker head studs you had the block drilled and retapped. So how much harder is it to have the head drilled out for larger dowels?</TD></TR></TABLE>
well when it was out i forgot to have it drilled for bigger dowels cause im an idiot but now the motor is built so the block will be fixed and dowels installed once the motor is in the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bootlegcivic &raquo;</TD></TR><TR><TD CLASS="quote">You don't have to do any machine work. Golden Eagle makes them they're cheap ($20) and you definitely need them.
http://cgi.ebay.com/ebaymotors...ZWDVW </TD></TR></TABLE>
i cant use those they are for normal sized studs i have oversized dowels for the studs that came with the arp oversized kit but thanks for the info
thansk for all the help everyone it is greatly appriciated
Old Oct 17, 2007 | 11:09 PM
Couldn't you have a machine shop or yourself carefully drill out the golden eagle dowel pins??
Old Oct 17, 2007 | 11:18 PM
SwappedTURBOegg's Avatar
its a toss up if you're NA you'll prolly be A OK for a while.. boosted high hp the head gasket tends to float around without them... you'll find out in time.
Old Oct 18, 2007 | 01:36 PM
Default Re: (SwappedTURBOegg)
yea im gonna wait til the head gaskit goes than i will be swapping cams and fixing the dowels so hopefully it all works out thanks for all the info guys
chicklet
May 28, 2018 05:19 PM
pinoy_93cb7
Jul 6, 2011 01:29 PM
modernvisionscc
Aug 3, 2007 12:06 PM
busychild
Sep 30, 2004 06:12 PM
t-blizzard
Feb 15, 2003 01:56 AM
