Done with custom turbo kit but HELP!
Old Aug 4, 2004 | 07:59 PM
quik sol's Avatar
Default Done with custom turbo kit but HELP!
Ok, I started it up using http://www.thedropshop.com for there vafc settings, yes I know there are just a base but whenever I start my car it revs up and down between 550 and 850 non-stop and wont let the car go over 15-20 mph I also have a check engine like #3 which is the map sensor would this cause this to go off or what? I set my settings exactly like they should be on thedropshop but I am getting a map sensor CEL. ANY help would be greatful.
Old Aug 4, 2004 | 09:52 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Done with custom turbo kit but HELP! (quik sol)
If I remember right, there is a thread on people running the hack, its 18 pages long..... search and see if you can pull it up... Should help a lot.
Blaze
Old Aug 5, 2004 | 05:07 PM
quik sol's Avatar
Anyone else with an answer?
Old Aug 5, 2004 | 05:09 PM
Bspec18's Avatar
Default Re: (quik sol)
Did you double check your wiring install ? Is the MAP Sensor or IACV plugged in good ?
Old Aug 5, 2004 | 05:24 PM
quik sol's Avatar
checked the wiring and its perfect. I can understand it running a little rough because of it not being tuned but it wont go over 20 mph?
spockeg
Oct 12, 2009 10:17 AM
Carbonciv
Sep 12, 2007 09:02 AM
whitestreak
Mar 3, 2007 05:56 AM
SDT Project EF
Aug 12, 2003 05:43 PM
.RTErnie
Mar 15, 2003 01:10 PM
