doing Drag turbo install now. need help
Old Jun 5, 2003 | 09:15 AM
Cowboy's Avatar
Default doing Drag turbo install now. need help
this is for a '00 prelude. how do you route that pipe into the hole?
thanks
Modified by Cowboy at 7:17 PM 6/5/2003
Modified by Cowboy at 7:23 PM 6/5/2003
Old Jun 5, 2003 | 09:36 AM
Hayasa15's Avatar
Default Re: doing Drag turbo install now. need help (Cowboy)
the pic is not working
Old Jun 5, 2003 | 09:38 AM
Cowboy's Avatar
Default Re: doing Drag turbo install now. need help (Hayasa15)
how do i post a picture?
Old Jun 5, 2003 | 10:11 AM
Honda4CX-T's Avatar
Like that .... You are using a PHP parsed URL you don't need this "&file=pipe2.jpg".
BTW, that looks like a drilled hole fopr the pipe routing a 180-Deg ben should fit in there with ssome modif.
Modified by Honda4CX-T at 6:08 PM 6/5/2003
Old Jun 5, 2003 | 10:39 AM
mamaboy's Avatar
if that's the car i think it is......use a dremel and you have to cut the actual metal out of the hole....you'll know what it is once you look there......pretty simple.....the smallest cutting wheel did that can you believe it.....
Old Jun 5, 2003 | 11:04 AM
Cowboy's Avatar
damn, that was what i didn't want to do
but thanks a lot!
i'll be grinding for the next hour
Old Jun 5, 2003 | 03:38 PM
Cowboy's Avatar
ok, i got it in after an *** load of grinding.
now it looks like the pipe is too tall and i don't think the hood will close. should i cut it down and couple it with a silicone joint, because it's originally one whole piece going from intercooler to turbo. or is there something else i should do?
thanks
Old Jun 6, 2003 | 03:22 AM
Honda4CX-T's Avatar
Yes you can couple it with silicone hose. and some good T-Clamps so it wil not "pop" out/off.
Old Jun 12, 2003 | 09:43 PM
TurboTeG4's Avatar
Default Re: doing Drag turbo install now. need help (Honda4CX-T)
When putting a drag 3 kit with a large spearco intercooler on a 93 coupe with b18c1 is there mods to make for the intercool???
Old Jun 13, 2003 | 03:28 AM
Honda4CX-T's Avatar
Default Re: doing Drag turbo install now. need help (turbocivic4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic4 &raquo;</TD></TR><TR><TD CLASS="quote">When putting a drag 3 kit with a large spearco intercooler on a 93 coupe with b18c1 is there mods to make for the intercool???</TD></TR></TABLE>
You will most likely have to "cut/modfy" your bumper support frame to acomodate a larger than normal IC. Plus customize the way you will route the piping as well.
NA EP3
Jun 5, 2003 10:11 AM
DeL SLo
Feb 21, 2003 02:07 PM
