Does this turbo fit?
Old May 14, 2011 | 09:41 AM
MalcolmV8's Avatar
Default Does this turbo fit?
I figured I'd make a new post for some ideas from those not following my build thread.
This is a Spoolin Performance header I got used. I got a Precision 5431 Turbo. It's a .50 trim billet compressor wheel unit. Exhaust A/R .63.
It touches the clutch slave on the bleeder screw. Pretty hard. Enough that I didn't snug the bolts all the way.
Also it sits really sideways. Is that normal? Looks really odd to me. I mean compressor side points right into the radiator. Even with a super slim fan that looks like it might be an issue?
What do you guys think? Is there a slave I can get to make this work or should I just get another header?
Old May 14, 2011 | 08:44 PM
TheShodan's Avatar
Moderator
Default Re: Does this turbo fit?
What you have is normal for the use of air conditioning and power steering. It is angled in such a way as to not need to shave the webbing on the engine block. What you need to do is to either notch out the fan shroud or get a slim fan that fits onto the radiator. As for the slave nipple, there should be no problem there as the filter seems to fit in front of them.
Old May 15, 2011 | 07:30 AM
MalcolmV8's Avatar
I don't think trimming the fan shroud will do it as the pipe would then go right into the fan blades. It's angled to much in there. I will try some slim line fans and see if that works.
The nipple on the slave is pressing up very hard against the turbo. Like it may snap it or damage something if I tighten up the header bolts all the way. That's why I was thinking maybe I can remove the nipple and perhaps cut it down shorter and re-install. Depends on what the ends look like though. It may not be possible to cut one down.
Old May 15, 2011 | 09:07 AM
LightningTeg's Avatar
Community Builder
I would try and get a 90* fitting there like I said. Or just get a different manifold. Not a whole lot of options.
As far as the fan, its almost neccesary to get a slim fan.
the-fan-man.com
Old May 15, 2011 | 05:43 PM
TheShodan's Avatar
Moderator
And you can't "cut the nipple". Like many nipples of different sizes and types, *snicker* they are needed for a reason (as in this case the need to bleed a slave cylinder may arise in the future). At the current angle, it looks like its pressing against the housing, but not affecting the actual function of the turbo at this current standpoint.
You'll find as you put this together, that even custom manifolds don't fit around everything perfectly, or assume that you're going to make some changes to surrounding equipment (the trimming of fan shrouds or use of slim fans, smaller sized radiators with higher capacity, the use of thermal or heat shielding on A/C components, etc).
This is never text book, plug and play. As you can tell you're going to experience a few miniscule surprises, but nothing that should shock you. Remember , these components were never designed to fit in this kind of engine bay, (despite its repeatability to the contrary in the aftermarket world.) Just expect some hiccups.
Old May 15, 2011 | 05:44 PM
91jdmhatchback's Avatar
I would just cut the nipple part off the fitting and see if that gives you enough room to tighten it down. If not remove it and see if it clears then.
Old May 15, 2011 | 08:34 PM
TheShodan's Avatar
Moderator
Are you referring to the fitting on the compressor cover, or the slave cylinder?
Old May 15, 2011 | 09:36 PM
VRD^don's Avatar
use a honda accord slave!! the nipple points upwards!!! i believe the prelude ones do as well!
Old May 16, 2011 | 05:09 AM
TheShodan's Avatar
Moderator
Correcto.
Old May 16, 2011 | 06:39 AM
MR.johnson's Avatar
x 2 on this.
make the slim fan a pusher on the front, then i dont see any problems at all. its going to be a tight fit for the DP.
Old May 19, 2011 | 08:24 PM
MalcolmV8's Avatar
Something must have happened to my email as I didn't see your replies till now. Thanks guys.
So honda accord or prelude slave will work. Good to know. Is there a specific year I want to get? I assume just go to local autoparts store and get one.
Great idea on the pusher fans. I know from doing v8 conversions on Ford Rangers and using pusher fans they don't work nearly as well as pullers but they will work. I haven't had a chance to see if there's clearance in front of the radiator on the Civic but if there is man that'll be a great option.
As for downpipe yeah it's gonna be a tight one but I think I can fab one to work.
Old May 19, 2011 | 09:01 PM
da_dude's Avatar
That must be my old manifold. What I did was trim the slave bleed screw. But the best route would be getting an accord/prelude slave.
Old May 20, 2011 | 05:46 AM
Bseriescivic5's Avatar
First off, you need to re-mount the turbo... from the pictures it looks like the oil drain is facing upwards, so thats an obvious issue. Re-mount it and see what the clearances are.
Old May 20, 2011 | 05:54 AM
kyden's Avatar
clocking the drain is not going to change placement of the turbo.
Old May 20, 2011 | 06:11 AM
MalcolmV8's Avatar
It could be. PM me your first name and we'll see. If it is I have a few questions on fitment if you don't mind.
clocking the center piece won't affect placement at all.
Yup what he said.
Old May 20, 2011 | 08:11 AM
00si2's Avatar
There is enough room in front of the rad for the slim fan.
Old Jul 9, 2011 | 12:01 PM
MalcolmV8's Avatar
Hey Guys, I got a Prelude slave as you suggested and the nipple points to the radiator and not upwards? anyhow I think it'll possibly give me the clearance I need. It wasn't a direct fit though. Had to slot one of the mounting bolts to make it work.
Prelude is above, Civic below.
Had to slot the one bolt hole like this to make it fit.
New nipple location which will hopefully give me the clearance I need.
Old Jul 9, 2011 | 12:43 PM
ShanghaiOC's Avatar
Looks good. Put the turbo in. You have room...and if you look around, they have a plate made for the manifold to straighten out the turbo. It's kinda over priced ($120ish) but giving you more options
Old Jul 9, 2011 | 01:13 PM
MalcolmV8's Avatar
Never heard of this plate but sounds good. Any links? I'd be interested in checking it out.
Old Jul 9, 2011 | 03:10 PM
da_dude's Avatar
Name is Keng.
Old Jul 10, 2011 | 05:30 AM
Schister66's Avatar
Man U FTW
...and this is why my GSR has no AC. Its too much of a hassle
Old Jul 10, 2011 | 05:45 AM
MalcolmV8's Avatar
Depends on where you live. Here in KC that's not an option. Today for example is 99F with heat index of 110F because it's so humid and muggy out you can barely stand to breath in it. Step outside and you start sweating immediately.
The Honda would be completely useless without A/C. Not gonna happen.
Old Jul 10, 2011 | 05:55 AM
TheShodan's Avatar
Moderator
There's always an option. Its called having another car for your hot days. I've lived in Mission KS, right outside on I-435, and though very, very hot, I knew it was time to drive something else instead of trying to drive a 350whp car and not have a back up. Out of the 3 cars you have in your sig list, none of the other ones have A/C to just switch for that day?
Old Jul 10, 2011 | 05:59 AM
MalcolmV8's Avatar
They all have A/C so I can drive any vehicle on any day. The Cobra has over 500 hp and ft/lbs to the tires and A/C. No reason the Honda can't have A/C too.
Old Jul 10, 2011 | 06:22 AM
TheShodan's Avatar
Moderator
Didn't say it couldn't but prepare for the headaches later, of failing compressor, not cool enough Air coming through the vents, etc. Remember, you're putting in something that originally wasn't totally designed for it. But.. to each.
