Does a thrown rod bearing affect compression #'s?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedingHatch »</TD></TR><TR><TD CLASS="quote">just went out and messed with it and got pummeled by an electric shock when my elbows were on the intake manifold, possibly on the distributor bridging the two.
Its gotta be a short or something and I hopped in the car and revd it up and its exactly at 2k rpm everytime.</TD></TR></TABLE>
Hmmm, I'd say check the distributor cap for cracks and the plug wires again...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">Hmmm, I'd say check the distributor cap for cracks and the plug wires again... </TD></TR></TABLE>
Everything checked out.
Maybe its the wiring to the distributor? I dunno. Poop
Maybe its the wiring to the distributor? I dunno. Poop</TD></TR></TABLE>
Something somewhere has to be shorting out in order to energize the intake manifold... Starter wire against the block?
I had this issue once. It was from rain though. It was raining really bad, and i don't have any of the parts that keep rain from your engine
well, got some water on distributor and plug wires. The issue was anytime i tried to accelerate no dice, missed badly. Light, to no throttle it was okay. I was feeling around, on the plug wires at the distributor, and zap, major shock, that **** hurts. Well, of course i had to make sure it wasn't a fluke, so i did it again, i know smart. So plulled of the wires, dried it all, put some dielectric grease and problem solved.
I don't really have much help to your situation, other then it def. sounds like you have a major short. You only get shocked when its running right... so likely not form your battery then, starter area. Have you spliced into any wires from your distributor or anything like that. Running MSD?
well, got some water on distributor and plug wires. The issue was anytime i tried to accelerate no dice, missed badly. Light, to no throttle it was okay. I was feeling around, on the plug wires at the distributor, and zap, major shock, that **** hurts. Well, of course i had to make sure it wasn't a fluke, so i did it again, i know smart. So plulled of the wires, dried it all, put some dielectric grease and problem solved. I don't really have much help to your situation, other then it def. sounds like you have a major short. You only get shocked when its running right... so likely not form your battery then, starter area. Have you spliced into any wires from your distributor or anything like that. Running MSD?
but whats strange is that this whole occurance was out of nowhere. it was running great for weeks, then, shuts off, and now it clicks and shocks.
And when the head was off, I went through the whole wiring harness and nothing was out of the oridinary.
I cant even drive it because it runs like **** at 2k rpm and bogs, etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IRONlung201 »</TD></TR><TR><TD CLASS="quote">This may be obvious, but have you checked around the fusebox for the noise? Youd di says this all started with the main fuse...</TD></TR></TABLE>
Its defintely Intake Manifold. The fuse box looks fine with no wires grounding our or anything
Do you have a meter? I'd start check for voltage on the intake manifold, then slowly pull each plug and see when it drop off. Repeat until you find the source of the voltage (assuming that there really is voltage emitting from the intake manifold), I could see that severly f-ing up some ****.
taffettaek9
12
Mar 27, 2008 04:43 PM
FuNkDrSpOt
15
Oct 15, 2007 03:03 AM
ActiveAero
Feb 6, 2007 08:33 AM
Mr. Softee
Nov 27, 2001 11:36 PM
