Does race gas go bad quickly?
Old Jan 30, 2003 | 05:22 AM
Holden's Avatar
Default Does race gas go bad quickly?
I recently crashed my winter beater and had to bring out my GSR for daily driving.
My car ran great the last time I drove it hard, early November at 50 degrees. Now, in 10-20 degree weather, I'm getting detonation like never before. I can even get detonation at 10" vacuum in 5th gear.
I ask about race gas because I filled it up in Novemeber with 1/2 a tank of 94 octane and 1/2 a tank of 100 octane unleaded.
Could the 2-3 month old race gas be causing problems?
TIA.
Old Jan 30, 2003 | 05:27 AM
boostin b16's Avatar
Default Re: Does race gas go bad quickly? (Holden)
why the hell are you getting detonation in vaccume? that is deffinitly not normal!! i have seen cars sit for a year with vp c16 leaded race gas and have no problems running. i cant say positivly its not the gas, but probably not. try checking your timing. are you sure its detonation your hearing?
Old Jan 30, 2003 | 08:33 AM
Holden's Avatar
Default Re: Does race gas go bad quickly? (boostin b16)
I have a J&S Safeguard that is picking up detonation where it never picked it up before.
I set all my VAFC settings that were negative to zero and checked that my FPR's are all still connected.
Fuel pressures appear normal.
I'll check timing and compression this weekend. It's easy enough not to boost, since the snow tires I have on can't hold boost in the first three gears anyway...
Old Jan 30, 2003 | 09:47 AM
SoulSurfer's Avatar
https://honda-tech.com/zerothread?id=396139
Old Jan 30, 2003 | 10:08 AM
JT's Avatar
JT
Default Re: Does race gas go bad quickly? (LSDelSol)
Anyone uses Sta-Bil in their tank during storage? http://www.goldeagle.com/sta-bil/faqs.htm
turbociv
Sep 23, 2005 06:23 AM
ITR981002
Apr 25, 2005 05:58 PM
95GLX
Mar 31, 2003 06:31 AM
wm5holla
Feb 1, 2003 08:49 AM
