does a precision SC60 is to big for me ... please look
Old Nov 5, 2003 | 05:15 AM
yellowturbo's Avatar
Default does a precision SC60 is to big for me ... please look
Ok I have fully buit D16Z6 and I am searching for a bigger turbo.... now I use a cutty tiny TDO4H-15G lol .... I use AEM EMS.
I need to know if it could be a nice upgrade.... Precision SC 60 OR MAYBE SC 61 I want to get around 350 whp ....
If you have any other idea...
Old Nov 5, 2003 | 05:18 AM
Tinker219's Avatar
Default Re: does a precision SC60 is to big for me ... please look (yellowturbo)
itll take awhile to spool, but for the money, the sc61 is the best turbo you can buy, and honestly, I dont think youll have problems spooling the turbo if you dont mind waiting a lil bit. Hey, that, or a lil sneaky pete to help spoolup
Old Nov 5, 2003 | 05:36 AM
what do you mean by a while ??? around 4000 rpm ??? or maybe less ??
Old Nov 5, 2003 | 05:37 AM
you talk about the sc61 .... how about the sc60 ?
Old Nov 5, 2003 | 05:38 AM
ELSpool's Avatar
Probably later than that. Will be a touch laggy with that trim, but make big efficient power high in the revs.
Old Nov 5, 2003 | 05:41 AM
which turbo I should use ... there is too many turbo out there and im so confused !!!
Old Nov 5, 2003 | 05:49 AM
Tinker219's Avatar
Default Re: (yellowturbo)
SC61 with a small exhaust housing(I think .48 is the smallest you can go) will be SWEET on a D series. Im going to attemp to spool a .63/.70 Garret 60-1 with my d15b7 Ill let you know how that goes
30psi Teg's Avatar
if you only want like 350 hp at the wheels why dont you look at getting something like the sc-50 or sc-32 these are probably more fitting for the hp you are wanting. Most 50trim t3/t4 would be fine for your app.
Old Nov 5, 2003 | 05:50 AM
rjardy's Avatar
you can make your WHP goal with an SC32, its smaller and you will spool it just fine, but it will still have enough to get you to your goal. thats my recomendation.
Rob
Old Nov 5, 2003 | 05:58 AM
BoostedsiR's Avatar
maybe around 5500, I hopr you did some head work so you can rev up to 9000,
my question is why? why a single? I dont think that I will ever understand
Old Nov 5, 2003 | 06:04 AM
ELSpool's Avatar
Default Re: (BoostedsiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR &raquo;</TD></TR><TR><TD CLASS="quote">
my question is why? why a single? I dont think that I will ever understand</TD></TR></TABLE>
I don't understand why people swap in a B when they can build a D for cheaper and still make 400whp?
Old Nov 5, 2003 | 06:28 AM
Tinker219's Avatar
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">
I don't understand why people swap in a B when they can build a D for cheaper and still make 400whp?</TD></TR></TABLE>
exactly, by the time you pay for the swap, there is your BUILT D. Hindsight is 20/20...*sigh*
Old Nov 5, 2003 | 06:30 AM
D-Man's Avatar
def a nice upgrade but overkill for only 350whp,an SC32 would be nice for that goal.
Old Nov 5, 2003 | 06:32 AM
Tinker219's Avatar
Default Re: does a precision SC60 is to big for me ... please look (D-Man)
ount know, for the same cost though, i say run the biggest turbo thats physically possible. There are always ways to improve lag, but when you max out a turbo, its VERY hard to get more out of the turbo. If he maxes out an SC61, world record D series POWA!
Old Nov 5, 2003 | 07:07 AM
D-Man's Avatar
Default Re: does a precision SC60 is to big for me ... please look (Tinker219)
well,my theory is that at 350whp the SC32 will jump all over the SC61 on a D because of the quicker spool responce....but I may be wrong until someone tries it
Old Nov 5, 2003 | 07:09 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">ount know, for the same cost though, i say run the biggest turbo thats physically possible. There are always ways to improve lag, but when you max out a turbo, its VERY hard to get more out of the turbo. If he maxes out an SC61, world record D series POWA!</TD></TR></TABLE>
LOL! I like your optimistic view...
But without fully building the D motor, it will be difficult to max out that big turbo.
For us "regular" folks who don't make those wierdo elephant trunk manifolds , the SC32 should be fine for all your boosting needs.
Old Nov 5, 2003 | 07:23 AM
WOW thank for all the tips.... but does the SC32 will push hard from is spool to the redline.... now this is what im searching for.... what could be a good compromise between thw sc32 and the sc61 ?????
oh yeah and what is the difference between 350 whp on a D or a B ??? IMO a hardcore D serie still over a B !!!! but anyway it is just a personnal question....
Old Nov 5, 2003 | 07:29 AM
Johnyquest's Avatar
Here's my input:
BoostedEd9 made 302 hp @ 16psi, stock d-series (did your raise or lower compression!?) with an SC50.
SO, you can probably get 350 or so maxxing out the sc50 -- possibly with a litte more compression, some headwork, etc, the sc50 would be the "best match" for a sub 400hp D. You might even be able to get more out of it.
The SC60 would be my second choice, just because I hate lag, and I do like to "max out" the turbo I pick (so it is used as efficiently as possible).
SC61 is getting a bit HUGE, so i say steer clear (it can push almost 600hp). There's no reason to get that big of a turbo unless you PLAN on making (or trying to make) that much power.
Either way, I say go with 10:1 compression if you haven't already, and an sc50. You WON'T be dissapointed... but you can go even farther with the 60!
Old Nov 5, 2003 | 07:34 AM
thank johnyquest ... you have awnsered to my question... I prefer max my turbo than to get a bigger with a lot of room and btw to be less efficient.... so the sc 50 could be good to reach 350 whp easily ... if I understood !
How much I should pay for a brand new Precision SC50 .... aprox. ???
Old Nov 5, 2003 | 07:36 AM
do you know if there is something between the SC 50 and the SC 60 ... just to know ?
Old Nov 5, 2003 | 07:49 AM
http://www.precisionte.com/sportcompact.php
there is a lot of possibility ....
Old Nov 5, 2003 | 08:54 AM
joek84's Avatar
anyone know about what kind i should put in my gsr for 250-280 whp from 5-8psi? Would the sc32 be a good setup. I read that sc50's aren't as efficient as sc60's or 61's
Old Nov 5, 2003 | 09:24 AM
anyone could suggest other idea or other brand of turbo ....
Fnix
Nov 14, 2011 11:49 AM
beaversdc5
Jun 21, 2007 07:16 PM
driveahonda
Nov 17, 2006 07:17 AM
wolve
Sep 21, 2006 07:26 AM
