Does this piping make sense to you?
Old May 8, 2007 | 11:58 AM
thenick's Avatar
Default Does this piping make sense to you?
On a bone stock DOHC ZC I would be running an IHI-RHB5 turbo connected to a STD. manifold. Does this seem feasible or should I go bigger; here were my plans:
1.75" to 2.25" on the hotside.
2.25" from the cold side (I'll be running a sidemount intercooler where the airbox used to be)
and a 2.5" downpipe to a 2.5" (2.75"? 3"? exhaust)
Is this feasible or am I going too small?
Old May 8, 2007 | 03:01 PM
Schister66's Avatar
Man U FTW
sounds fine for how small the turbo is...
Old May 8, 2007 | 10:27 PM
thenick's Avatar
Default Re: (Schister66)
Cool.
Old May 8, 2007 | 10:40 PM
riceball777's Avatar
Default Re: Does this piping make sense to you? (thenick)
sounds fine for such low Hp numbers
many stock turbo cars like sr20's and even evos use 1.5 inch intercooler piping
Old May 9, 2007 | 08:19 AM
White Smoke's Avatar
i my honda
Global Mod
Piping setup sounds fine but the sidemount idea has been proven to totally suck w/o extensive duct work and bumper hacking. Make sure you do your research on that.
Old May 9, 2007 | 08:28 AM
thenick's Avatar
Default Re: Does this piping make sense to you? (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">Piping setup sounds fine but the sidemount idea has been proven to totally suck w/o extensive duct work and bumper hacking. Make sure you do your research on that. </TD></TR></TABLE>
Hmmm -- my main concerns were route piping (want it minimized). I have no problems running a front mount but I was under the assumption a non-oem sidemount such as an HKS would function ok for my needs?
Old May 9, 2007 | 11:33 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm -- my main concerns were route piping (want it minimized). I have no problems running a front mount but I was under the assumption a non-oem sidemount such as an HKS would function ok for my needs?</TD></TR></TABLE>
It will with ducting. Any car that has a sidemount already has provisions for it and an aftermarket one can be used in it's place for better performance. Honda's don't so you will have to do some custom work. Honestly, Id recommend the front mount even if you have to add another foot or two of piping. Look into a back door intercooler. The IAT temps will make up for the difference.
Old May 9, 2007 | 11:54 AM
thenick's Avatar
Thanks for the heads up. Sans new intercoolers, do you know of any stock cars that had backdoor style intercoolers? Do the EVOs have these?
Old May 9, 2007 | 12:02 PM
Schister66's Avatar
Man U FTW
SRTs use a backdoor setup....if you search http://www.homemadeturbo.com there is a writeup on how to make that IC work on an EG chassis....it may give you an idea if you use a different one
Old May 9, 2007 | 12:19 PM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick &raquo;</TD></TR><TR><TD CLASS="quote">Do the EVOs have these?</TD></TR></TABLE>
No
You can buy a core and just have some end tanks welded on for a reasonable price. There used to be a bunch of backdoor intercoolers on ebay but allot are now gone.
Here is a stock srt one http://cgi.ebay.com/ebaymotors...QrdZ1
joppe
Aug 28, 2009 12:54 AM
Scheizty
Dec 4, 2007 05:46 AM
punkinbeck
Sep 26, 2007 03:58 AM
wacky96d16
Jan 12, 2005 01:23 PM
Fuzion
Sep 17, 2003 11:59 AM
