Does Ford make a 2 bar map sensor?
Old Feb 22, 2003 | 09:31 PM
scooter's Avatar
Default Does Ford make a 2 bar map sensor?
I was browsing through the Junkyard and ran across a Turbo Mercury Capri. I noticed the map was still there so I took it, figuring it was 2 bar by looking at the boost gauge on the gauge cluster (15psi).
Anyone every try one of these maps?
scott
Old Feb 22, 2003 | 10:16 PM
turbo Si's Avatar
Default Re: Does Ford make a 2 bar map sensor? (scooter)
I have a brand new GM 2 bar for sale!
Old Feb 22, 2003 | 10:23 PM
inspyral's Avatar
Default Re: Does Ford make a 2 bar map sensor? (turbo Si)
Do you mean 3BAR? The OEM Honda MAP is 2BAR, if I'm not mistaken.
Old Feb 22, 2003 | 11:28 PM
scooter's Avatar
I can pick up GM 2 bars at the junkyard for a $1 all day long.
scott
Old Feb 23, 2003 | 06:24 AM
turbo Si's Avatar
Default Re: Does Ford make a 2 bar map sensor? (inspyral)
No there all 1 bar.
Old Feb 23, 2003 | 08:39 PM
scooter's Avatar
anyone?? I just found out that this is a Mazda peice. Apparently Mazda did the motor set up for Ford in these cars...
Question still stands...anyone know anything about this map sensor?
thanks
scott
Old Feb 23, 2003 | 09:08 PM
BlueSi2k's Avatar
No there all 1 bar.
If it was 1 bar it wouldn't read any boost. It would read atmospheric pressure which is 14.7psi and nothing more.
Old Feb 23, 2003 | 10:23 PM
MiraiZ's Avatar
Default Re: Does Ford make a 2 bar map sensor? (BlueSi2k)
Hmmm...I thought Hondas read up to 11psi (under 1 BAR)
Old Feb 24, 2003 | 06:43 AM
BlueSi2k's Avatar
Default Re: Does Ford make a 2 bar map sensor? (MiraiZ)
Yes but thats 11psi over atmospheric which is already around 1 bar, so the honda sensor reads 14.7psi plus ~11 psi
Hybrid
Jun 27, 2003 05:15 PM
Javier
Mar 10, 2003 03:58 PM
0-60n4
May 23, 2002 03:58 PM
0-60n4
May 22, 2002 07:39 AM
Pro-Lude
Aug 29, 2001 04:26 AM
