does a catchcan need a breather/vacuum source???
Old Jul 12, 2006 | 02:21 PM
blackeg's Avatar
Default does a catchcan need a breather/vacuum source???
today i decided to use a coolant reservoir from an ef as my catchcan for my lsvtec turbo. the car gets coolant passing by and the reservoir is bigger than my rre catchcan.
i dont have any breather or vacuum hooked up to this one though, would it still be ok to use. should i put a hole in it or something to let it drain pressure when im under boost??? take a look, what do you guys think?
Modified by blackeg at 6:34 PM 7/12/2006
Old Jul 12, 2006 | 02:39 PM
RyanEJ8's Avatar
Default Re: does a catchcan need a breather/vacuum source??? (blackeg)
Do you still have the PCV valve in?
Old Jul 12, 2006 | 02:43 PM
areyouasian's Avatar
put a hole in it or else you'd just have pressure building inside the reservior
Old Jul 12, 2006 | 03:09 PM
blackeg's Avatar
Default Re: does a catchcan need a breather/vacuum source??? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Do you still have the PCV valve in?</TD></TR></TABLE>
no i do not. that vacuum line runs from the top of the black box on the rear of the block to the bottle. thats been my setup for a while
Old Jul 12, 2006 | 04:58 PM
turbotime's Avatar
so you removed the valve completely?
You will need to add some holes in the top of the resevoir, your going to want to add like 15 small to medium holes in it... basically you want that route to be the route of least restriction for your blowby gasses, more holes the better but dont go too crazy as your limited somewhat by that tiny hose...
for reference most setup use -10 or -12 an lines which are very large...
But yeah im just rambling now, add some holes on top and ur good
Old Jul 12, 2006 | 05:19 PM
blackeg's Avatar
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">so you removed the valve completely?
But yeah im just rambling now, add some holes on top and ur good</TD></TR></TABLE>
haha its ok i get what you are saying. im contemplating putting a barb fitting in the reservoir and running the hose back to my intake right before my turbo, which is the way ive had it for a long time.
Old Jul 13, 2006 | 08:26 PM
blackeg's Avatar
Default Re: (blackeg)
ok i put maybe 6-8 holes in the top, around the cap basically. hoping this will let the pressure out while still retaining any fluid that builds up.
Old Jul 14, 2006 | 07:22 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">add some holes on top and ur good</TD></TR></TABLE>
DuhQbnSiLo
Jun 26, 2009 08:34 PM
Mikes2000civicsi
Oct 26, 2007 05:28 PM
mortificationrock
Jul 17, 2007 08:52 PM
AaronJ
Aug 11, 2006 06:29 AM
